跳转到主内容
HP Envy 23-d060qd TouchSmart Speaker Replacement
Zachary Dicks
Zachary Dicks6 其他贡献者
最后更新于 December 28, 2017
15分钟
中等
My computer won't play audio even though I've checked all of the connections. How can I have a dance party without any audio? Luckily the party starts in 15 minutes so I have time to replace the speakers.
你所需要的
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. HP Envy 23-d060qd TouchSmart Speaker Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Use your hands to unclip the plastic snaps on the back panel of the device.
  2. HP Envy 23-d060qd TouchSmart Speaker Replacement: 步骤 2 中的图像 1,1
    • Remove the three 11.5mm PH2 screws from the back panel.
    • The screws will not fall out of the back panel, but they will unscrew to release the back panel.
  3. HP Envy 23-d060qd TouchSmart Speaker Replacement: 步骤 3 中的图像 1,1
    • Now, take the back panel off by pulling at it gently with your hands.
  4. HP Envy 23-d060qd TouchSmart Speaker Replacement, Speakers: 步骤 4 中的图像 1,1
    • Remove the receiver for the keyboard and mouse with your hands.
  5. HP Envy 23-d060qd TouchSmart Speaker Replacement: 步骤 5 中的图像 1,2 HP Envy 23-d060qd TouchSmart Speaker Replacement: 步骤 5 中的图像 2,2
    • Remove the four 17.5mm T15 screws from the speakers.
    • Remove the five 7.5mm T15 screws from the cover plate.
    • Remove the cover plate with your hands.
  6. HP Envy 23-d060qd TouchSmart Speaker Replacement: 步骤 6 中的图像 1,2 HP Envy 23-d060qd TouchSmart Speaker Replacement: 步骤 6 中的图像 2,2
    • Disconnect the two speaker connections from the motherboard with your hands. Use your hands to gently pull the plastic piece at the ends of the wires.
    • Be gentle when disconnecting any wired connections. Pulling on the wires can damage them.
  7. HP Envy 23-d060qd TouchSmart Speaker Replacement: 步骤 7 中的图像 1,2 HP Envy 23-d060qd TouchSmart Speaker Replacement: 步骤 7 中的图像 2,2
    • Remove the speakers from the computer, and if needed, separate by disconnecting the wires between them.
    • Be gentle when separating wired connections. Pulling on the wires can damage them.
结论
Zachary Dicks
于10/01/15注册
1,135 声望
创作了7篇指南
团队
Cal Poly, Team 5-10, Maness Fall 2015 Cal Poly, Team 5-10, Maness Fall 2015 的会员
CPSU-MANESS-F15S5G10
4 名成员
创作了14篇指南
一条评论
where to get the replacement speaker???????
Clovis Young - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 19
总计 1,549
