跳转到主内容
HP Envy 23-d060qd TouchSmart Fan Replacement
Zachary Dicks
Zachary Dicks6 其他贡献者
最后更新于 December 28, 2017
15分钟
中等
My computer is heating up! Is it catching a fever? What can I do to keep it at its normal temperature? Replacing the fan should not be too difficult.
你所需要的
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. HP Envy 23-d060qd TouchSmart Fan Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Use your hands to unclip the plastic snaps on the back panel of the device.
  2. HP Envy 23-d060qd TouchSmart Fan Replacement: 步骤 2 中的图像 1,1
    • Remove the three 11.5mm PH2 screws from the back panel.
    • The screws will not fall out of the back panel, but they will unscrew to release the back panel.
  3. HP Envy 23-d060qd TouchSmart Fan Replacement: 步骤 3 中的图像 1,1
    • Now, take the back panel off by pulling at it gently with your hands.
  4. HP Envy 23-d060qd TouchSmart Fan Replacement, Fan: 步骤 4 中的图像 1,2 HP Envy 23-d060qd TouchSmart Fan Replacement, Fan: 步骤 4 中的图像 2,2
    • Remove the five 7.5mm T15 screws from the cover plate.
    • Remove the cover plate.
  5. HP Envy 23-d060qd TouchSmart Fan Replacement: 步骤 5 中的图像 1,2 HP Envy 23-d060qd TouchSmart Fan Replacement: 步骤 5 中的图像 2,2
    • Use your hands to separate the fan's wired connection to the motherboard. Use your hands to gently pull the plastic piece at the ends of the wires.
    • Be gentle when you separate wired connections. Pulling on the wires can damage them.
  6. HP Envy 23-d060qd TouchSmart Fan Replacement: 步骤 6 中的图像 1,1
    • Remove the three 8mm T15 screws from the fan.
  7. HP Envy 23-d060qd TouchSmart Fan Replacement: 步骤 7 中的图像 1,1
    • Pull the fan loose from the computer.
结论
3等其他人完成本指南。
Zachary Dicks
于10/01/15注册
1,135 声望
创作了7篇指南
团队
Cal Poly, Team 5-10, Maness Fall 2015 Cal Poly, Team 5-10, Maness Fall 2015 的会员
CPSU-MANESS-F15S5G10
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 15
过去 30 天: 34
总计 3,884
