HP Envy 17-J013CL WLAN Module Replacement
5分钟
简单
简介
转到步骤 1The WLAN module works the wifi that comes and goes from the laptop. So replacing this whenever goes faulty is important and thankfully is easy to fix! Be sure to keep yourself grounded to eliminate static!
你所需要的
Use a PH1-screwdriver to loosen the 7mm screw. The screw will not fully come out as it is held by a washer underneath but will come out enough to open it.
即将完成!
结论
另外一个人完成了本指南。
