跳转到主内容
HP EliteBook x360 1030 G3 Touchpad Replacement
Heather Laporte
Heather Laporte2 其他贡献者
最后更新于 December 9, 2023
15 - 25 分钟
中等
The HP EliteBook x360 1030 G3 is a 2-in-1 laptop which means it can function as a tablet or computer. However, to function as a computer, it is essential to have a functioning touchpad.
The touchpad is the direct link to the screen from your keyboard and if it fails to work many applications of the computer may become harder. This guide details how to remove and replace the Touchpad element should it stop functioning. It is below the battery of the laptop and requires an ESD-safe Opening Tool to prevent any damage to the computer.
你所需要的
工具
查看更多...
  1. HP EliteBook x360 1030 G3 Touchpad Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Touchpad Replacement: 步骤 2 中的图像 1,1
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 Touchpad Replacement, Battery: 步骤 3 中的图像 1,1
    • Remove the five 3.7 mm screws that are holding the battery in place using a Phillips #00 screwdriver.
    • Be sure to keep the screws organized because they will be reused for the next battery installation.
  4. HP EliteBook x360 1030 G3 Touchpad Replacement: 步骤 4 中的图像 1,2 HP EliteBook x360 1030 G3 Touchpad Replacement: 步骤 4 中的图像 2,2
    • Carefully pull the white plastic battery connector towards you until it is removed from the port.
    • Be sure not to pull using the wires; doing so may cause damage.
  5. HP EliteBook x360 1030 G3 Touchpad Replacement: 步骤 5 中的图像 1,1
    • Gently lift the battery out of its place.
  6. HP EliteBook x360 1030 G3 Touchpad Replacement, Touchpad: 步骤 6 中的图像 1,2 HP EliteBook x360 1030 G3 Touchpad Replacement, Touchpad: 步骤 6 中的图像 2,2
    • Remove the six 1.95 mm JIS #000 screws that secure the metal frame of the touchpad.
  7. HP EliteBook x360 1030 G3 Touchpad Replacement: 步骤 7 中的图像 1,3 HP EliteBook x360 1030 G3 Touchpad Replacement: 步骤 7 中的图像 2,3 HP EliteBook x360 1030 G3 Touchpad Replacement: 步骤 7 中的图像 3,3
    • Lift the small white ZIF connector from the front using a spudger tool or your finger.
    • Only lift the white hinge securing the Flexed Flat Cable making sure the unit stays secure to the board.
  8. HP EliteBook x360 1030 G3 Touchpad Replacement: 步骤 8 中的图像 1,1
    • Pull the yellow and orange striped ribbon away.
  9. HP EliteBook x360 1030 G3 Touchpad Replacement: 步骤 9 中的图像 1,1
    • Lift the touchpad up from the computer board by the metal frame.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 30
总计 983
