HP EliteBook x360 1030 G3 Screen Replacement
简介
转到步骤 1This guide will show you how to remove the screen from the laptop.
This will not explain how to remove the entire monitor. For that, see HP’s service manual for info about display assembly replacement.
你所需要的
Open the laptop and position the screen to face you.
Carefully wedge a Jimmy between the black screen border and the silver monitor backing, and then rotate the Jimmy upwards and away from you until they separate.
5等其他人完成本指南。
1指南评论
I tried to perform this operation, since the top cover got a scratch and a ding. I bought a replacement top cover and tried to reinstall a perfectly working screen from one cover to another. I followed this manual to step 2 and realized that top is easy, sides are much harder. On the sides with the opener tool you start to touch directly the screen glass so the “slowly twist“ move suggested in this manual would likely create cracks in it. Finally I decided not to execute this procedure since the risk of losing the screen is too high. In case you replace a broken screen - then it is ok.
