在这个步骤中使用的工具:iFixit Opening Tool$1.99
Use your fingernail or the iFixit Opening Tool.
Start on the far side when prying apart.
Open the computer.
Separate gently the back cover from the front panel (keyboard panel).
Open each side gently (keyboard panel is facing up, the back cover is facing down).
Store the back cover.
You now have access to the mainboard.
Note that the battery is attached using different screws and you need a corresponding screw driver
7等其他人完成本指南。
2指南评论
Are the 6 silver-colored screws holding the back cover on all the same length?
David Cary - 回复
Pour voir au changer la batterie comment faire ?
Brahim Jelti - 回复
