跳转到主内容
HP Compaq nc6400 Screen Replacement
Luis Vazquez
Luis Vazquez5 其他贡献者
最后更新于 July 15, 2014
30分钟
中等
This guide will take you through the process of replacing the screen on an HP Compaq nc6400 Laptop. You will need the correct replacement screen for your laptop to complete the installation.
你所需要的
工具
查看更多...
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. HP Compaq nc6400 Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off and unplug laptop.
  2. HP Compaq nc6400 Screen Replacement: 步骤 2 中的图像 1,1
    • Locate the battery lock below the battery labeled one.
    • Slide the lock all the way to the left to release the left lock of the battery.
  3. HP Compaq nc6400 Screen Replacement: 步骤 3 中的图像 1,1
    • Locate the lock labeled two at the bottom right corner below the battery.
    • Slide and hold the lock to the left.
    10.8 volt ????
    OK ?
    Gilbert Baum - 回复
    the volt is 10.8,,?
    Gilbert Baum - 回复
  4. HP Compaq nc6400 Screen Replacement: 步骤 4 中的图像 1,1
    • Once both the battery locks are unlocked, slide the battery out to remove.
  5. HP Compaq nc6400 Screen Replacement, Screen: 步骤 5 中的图像 1,1
    • Remove the four 1.2mm Philips #1 screws attaching the plastic cover to the monitor.
    • The screws may have a small, black plastic cover that lays flush with the screen. Remove these using a pointed tool such as the spudger or philips head screwdriver by prying them out.
  6. HP Compaq nc6400 Screen Replacement: 步骤 6 中的图像 1,1
    • Remove the four 1.2 Philips #1 screws attaching the face plate to the body.
  7. HP Compaq nc6400 Screen Replacement: 步骤 7 中的图像 1,3 HP Compaq nc6400 Screen Replacement: 步骤 7 中的图像 2,3 HP Compaq nc6400 Screen Replacement: 步骤 7 中的图像 3,3
    • Pry up the plastic screen cover using a pry tool.
    • Keeping the pry tool under the trim, slide it around the entire screen until the the cover has completely detached from the base.
    • You might need to slide the display clip on the top of the screen in order to fully remove the plastic cover.
  8. HP Compaq nc6400 Screen Replacement: 步骤 8 中的图像 1,2 HP Compaq nc6400 Screen Replacement: 步骤 8 中的图像 2,2
    • Remove the two 1.2 Philips #1 screws holding down the sensor board at the bottom of the monitor.
  9. HP Compaq nc6400 Screen Replacement: 步骤 9 中的图像 1,1
    • Remove the right-most 1.2mm Philips #1 screw on the bottom of the monitor.
  10. HP Compaq nc6400 Screen Replacement: 步骤 10 中的图像 1,2 HP Compaq nc6400 Screen Replacement: 步骤 10 中的图像 2,2
    • Without lifting the bottom of the monitor, gently flip the screen and lay it face down on the keyboard.
  11. HP Compaq nc6400 Screen Replacement: 步骤 11 中的图像 1,2 HP Compaq nc6400 Screen Replacement: 步骤 11 中的图像 2,2
    • Remove the tape holding down the video cable to the monitor.
    • Gently pull out the video cable from the monitor.
  12. HP Compaq nc6400 Screen Replacement: 步骤 12 中的图像 1,2 HP Compaq nc6400 Screen Replacement: 步骤 12 中的图像 2,2
    • Remove the monitor's power cable from the sensor board.
    • This is the cable on the farthest right of the sensor board.
  13. HP Compaq nc6400 Screen Replacement: 步骤 13 中的图像 1,2 HP Compaq nc6400 Screen Replacement: 步骤 13 中的图像 2,2
    • Once all cables attaching the casing to the monitor have been disconnected, remove the entire screen from the computer and lay it on a flat surface.
    • Remove the four 1.2 Philips #1 screws attaching the bezel to the right side of the monitor.
    • Attach bezel to replacement screen.
结论
4等其他人完成本指南。
Luis Vazquez
于09/24/13注册
401 声望
创作了2篇指南
团队
Cal Poly, Team 14-6, Forte Fall 2013 Cal Poly, Team 14-6, Forte Fall 2013 的会员
CPSU-FORTE-F13S14G6
5 名成员
创作了5篇指南
1指南评论
Nicely done. Thanks?
Peter Q. - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 30
总计 5,491
