跳转到主内容
HP Compaq Presario V3000 Battery Replacement
Ricky Jaimez
Ricky Jaimez6 其他贡献者
最后更新于 May 11, 2017
5分钟
简单
Battery replacement is a relatively easy task that requires no tools. Just be sure that you have removed the power plug and allowed the laptop time to cool down.
  1. HP Compaq Presario V3000 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the laptop is powered OFF. Gently turn the laptop over and place it on a flat surface.
    • The battery may be warm or even HOT to the touch.
    • Locate the battery EJECT latch.
  2. HP Compaq Presario V3000 Battery Replacement: 步骤 2 中的图像 1,2 HP Compaq Presario V3000 Battery Replacement: 步骤 2 中的图像 2,2
    • Grab the laptop firmly on the side and using your thumb, press the eject latch towards the OUTER edge of the device.
    • The battery will be lifted out of the laptop slightly as you press the latch over as far as it will go.
    • When replacing the battery, you DO NOT need to adjust the latch. Once the battery is replaced, snap it into place and the latch will return to normal.
  3. HP Compaq Presario V3000 Battery Replacement: 步骤 3 中的图像 1,2 HP Compaq Presario V3000 Battery Replacement: 步骤 3 中的图像 2,2
    • Pull the battery up and towards you to remove it from the laptop chassis.
    • Once the battery is out, you will be able to check the battery label for the replacement part number.
    • The part number is needed when purchasing a new battery.
结论
3等其他人完成本指南。
Ricky Jaimez
于07/20/16注册
369 声望
创作了2篇指南
团队
1指南评论
I need the battery remove switch
Aadhi Dev - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 26
总计 2,569
