跳转到主内容
HP Compaq 6910p Processor Replacement
Tyler Fricks
Tyler Fricks4 其他贡献者
最后更新于 December 14, 2017
20分钟
中等
In this guide, we will illustrate how to remove and replace the processor of this device. Required tools include one Phillips screwdriver, one T9 Torx screwdriver, Arctic Silver Thermal Paste, and thumbs of course. Because the processor is difficult to find, patience will be required as well.
你所需要的
工具
查看更多...
  1. HP Compaq 6910p Processor Replacement, Processor: 步骤 1 中的图像 1,2 HP Compaq 6910p Processor Replacement, Processor: 步骤 1 中的图像 2,2
    • Turn the laptop upside down.
    • Remove the fourteen 1.5 cm Phillips's #1 screws.
    • Remove the battery.
    • Remove three 0.3 cm Phillips #1 screws in the battery compartment.
  2. HP Compaq 6910p Processor Replacement: 步骤 2 中的图像 1,3 HP Compaq 6910p Processor Replacement: 步骤 2 中的图像 2,3 HP Compaq 6910p Processor Replacement: 步骤 2 中的图像 3,3
    • Slide the tabs upward to release the keyboard
    • Lift up the keyboard
    • Disconnect the cables attaching the keyboard to the laptop by lifting up the release tabs.
    • Use a spudger if you're having trouble lifting up the tabs.
  3. HP Compaq 6910p Processor Replacement: 步骤 3 中的图像 1,1
    • Remove the upper frame of the laptop
    • This part is difficult, so use a spudger if you're having trouble removing the frame.
  4. HP Compaq 6910p Processor Replacement: 步骤 4 中的图像 1,3 HP Compaq 6910p Processor Replacement: 步骤 4 中的图像 2,3 HP Compaq 6910p Processor Replacement: 步骤 4 中的图像 3,3
    • Loosen the four 1.5 cm Phillips #1 screws indicated in red.
    • Remove the heat sink to reveal the processor.
  5. HP Compaq 6910p Processor Replacement: 步骤 5 中的图像 1,1
    • Lift up the processor carefully to remove
结论
7等其他人完成本指南。
Tyler Fricks
于10/22/15注册
528 声望
创作了5篇指南
团队
Montana Tech, Team 3-2, Shirk Fall 2015 Montana Tech, Team 3-2, Shirk Fall 2015 的会员
MTUM-SHIRK-F15S3G2
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 35
总计 4,662
