跳转到主内容
HP Compaq 6710b Wireless Card Replacement
Khulan Orgil
Khulan Orgil4 其他贡献者
最后更新于 January 25, 2016
10分钟
简单
Make sure your computer is off and battery is out before attempting to replace your wireless adaptor.
你所需要的
工具
  1. HP Compaq 6710b Wireless Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off your computer! Taking out the battery while it's still on is dangerous!
    • Flip the laptop over to the back.
    • Using two hands, push on the tabs while gently taking out the battery.
  2. HP Compaq 6710b Wireless Card Replacement, Wireless Card: 步骤 2 中的图像 1,2 HP Compaq 6710b Wireless Card Replacement, Wireless Card: 步骤 2 中的图像 2,2
    • Make sure the computer is off.
    • Using a Phillips #1, unscrew the 5mm screw on the bottom of the laptop
    • Remove the back cover plate.
    • The cover has popping tabs so it might require a small amount of force to remove.
  3. HP Compaq 6710b Wireless Card Replacement: 步骤 3 中的图像 1,2 HP Compaq 6710b Wireless Card Replacement: 步骤 3 中的图像 2,2
    • Using a blue plastic prying tool, gently pry off the 2 connectors.
    • The black cable goes on the connection closer to where the cables originate, while the white cable goes on the farther connection.
  4. HP Compaq 6710b Wireless Card Replacement: 步骤 4 中的图像 1,2 HP Compaq 6710b Wireless Card Replacement: 步骤 4 中的图像 2,2
    • Using the Phillips #1 screwdriver, unscrew the 2 3mm screws.
    • Adaptor is spring-loaded.
    • You can now take out the adaptor.
结论
2等其他人完成本指南。
Khulan Orgil
于04/14/15注册
1,171 声望
创作了6篇指南
团队
Cal Poly, Team 4-2, Maness Spring 2015 Cal Poly, Team 4-2, Maness Spring 2015 的会员
CPSU-MANESS-S15S4G2
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 15
过去 30 天: 36
总计 2,587
