简介
Replace your screen quickly and easily!
你所需要的
Flip the laptop over to the back.
Using two hands, push on the tabs while gently taking out the battery.
Flip to the backside of the laptop.
Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
Using the same screwdriver, unscrew the 8mm screws.
Put a finger under each side of the plastic lock on the ribbon cable and pull up.
Using a flathead screwdriver, work both sides of the connector next to the fan and take it out.
8等其他人完成本指南。
