跳转到主内容
HP Compaq 2510p Power/audio bar Replacement
Derek Kohansky
Derek Kohansky2 其他贡献者
最后更新于 December 26, 2016
10分钟
中等
不正确的工具
This guide will show step-by-step instruction depicting the replacement of your laptops power/audio bar.
你所需要的
工具
  1. HP Compaq 2510p Power/audio bar Replacement, Power/audio bar: 步骤 1 中的图像 1,1
    • Locate the 4 screws in the four corners of the laptop screen.
    • The screws may be hidden underneath a small rubber pad.
    • Be sure to ground yourself and tools before working near electronics.
  2. HP Compaq 2510p Power/audio bar Replacement: 步骤 2 中的图像 1,1
    • Use a Flathead screwdriver to remove the 4 rubber covers over the 4 screws referenced in step 1.
  3. HP Compaq 2510p Power/audio bar Replacement: 步骤 3 中的图像 1,1
    • Once the rubber has been removed a screw will be revealed. Remove each of the four screws with your Philips head screwdriver.
  4. HP Compaq 2510p Power/audio bar Replacement: 步骤 4 中的图像 1,1
    • Insert your spudger along the top of the screen, separating the plastic cover and the screen
  5. HP Compaq 2510p Power/audio bar Replacement: 步骤 5 中的图像 1,1
    • Continue running your Flathead along the top of the screen until the top is completely separated.
  6. HP Compaq 2510p Power/audio bar Replacement: 步骤 6 中的图像 1,2 HP Compaq 2510p Power/audio bar Replacement: 步骤 6 中的图像 2,2
    • Pull the plastic covering of the screen towards the keyboard, exposing the inner workings of the screen.
  7. HP Compaq 2510p Power/audio bar Replacement: 步骤 7 中的图像 1,1
    • Locate the hinges at the bottom left, and right of the screen
  8. HP Compaq 2510p Power/audio bar Replacement: 步骤 8 中的图像 1,2 HP Compaq 2510p Power/audio bar Replacement: 步骤 8 中的图像 2,2
    • Separate the Power/Audio bar from the hinge by gently pulling.
  9. HP Compaq 2510p Power/audio bar Replacement: 步骤 9 中的图像 1,1
    • Flip the Power/Audio bar over exposing the ribbon wire and its connection to the Power/Audio bar.
  10. HP Compaq 2510p Power/audio bar Replacement: 步骤 10 中的图像 1,1
    • Separate the ribbon wire by gently pulling the wire from its socket.
    • The wire will be separated and the bar is free.
    • Be gentle as you pull.
结论
另外一个人完成了本指南。
Derek Kohansky
于10/26/16注册
297 声望
创作了2篇指南
团队
UMass Dartmouth, Team 3-8, Isaacson Fall 2016 UMass Dartmouth, Team 3-8, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S3G8
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 420
