跳转到主内容
HP Compaq 2510p Bluetooth Adapter Replacement
Derek Kohansky
Derek Kohansky2 其他贡献者
最后更新于 December 26, 2016
10分钟
简单
This guide will show step-by-step instructions to replace the bluetooth adapter in the HP Compaq 2510p. .
你所需要的
工具
  1. HP Compaq 2510p Bluetooth Adapter Replacement, Bluetooth Adapter: 步骤 1 中的图像 1,1
    • Place the laptop upside down, with the battery facing away from you. Towards the bottom-middle of the laptop, you should see a small panel with a Bluetooth symbol.
  2. HP Compaq 2510p Bluetooth Adapter Replacement: 步骤 2 中的图像 1,1
    • There is 1 screw on the panel you located in step one. Use your Philips head screwdriver to remove the single screw.
  3. HP Compaq 2510p Bluetooth Adapter Replacement: 步骤 3 中的图像 1,1
    • Remove the Bluetooth panel by pulling it with your finger.
    • Pull gently as there is a wire connecting the laptop and the adapter.
  4. HP Compaq 2510p Bluetooth Adapter Replacement: 步骤 4 中的图像 1,1
    • Pull the adapter to the left exposing its underside. Locate and remove its only screw using your Phillip's head screwdriver.
  5. HP Compaq 2510p Bluetooth Adapter Replacement: 步骤 5 中的图像 1,1
    • Separate the Bluetooth adapter by pulling it from its casing.
  6. HP Compaq 2510p Bluetooth Adapter Replacement: 步骤 6 中的图像 1,1
    • Remove the adapter by pulling on the base of the connecting wires and the adapter, in opposite directions.
    • Use moderate force.
结论
3等其他人完成本指南。
Derek Kohansky
于10/26/16注册
297 声望
创作了2篇指南
团队
UMass Dartmouth, Team 3-8, Isaacson Fall 2016 UMass Dartmouth, Team 3-8, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S3G8
3 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 444
