跳转到主内容
加入维修社区 - 创建账户
HP 15-ef RAM Replacement
你所需要的
    1. HP 15-ef RAM Replacement, Prepare your laptop for disassembly: 步骤 1 中的图像 1,1
      • Fully shut down your laptop and unplug all cables.
      询问修复机器人
      添加评论
    1. HP 15-ef RAM Replacement, Flip your laptop over: 步骤 2 中的图像 1,1
      • Flip your laptop over so the rubber feet are facing up.
      询问修复机器人
      添加评论
    2. HP 15-ef RAM Replacement, Peel up an end of the front foot: 步骤 3 中的图像 1,3 HP 15-ef RAM Replacement, Peel up an end of the front foot: 步骤 3 中的图像 2,3 HP 15-ef RAM Replacement, Peel up an end of the front foot: 步骤 3 中的图像 3,3
      • The rubber feet cover a total of six back cover screws.
      • Use an opening pick to peel up an end of the front rubber foot until you can grip it with your fingers.
      • Make sure both the foot and its adhesive peel up together, as they need to be removed as one piece.
      询问修复机器人
      添加评论
    3. HP 15-ef RAM Replacement, Remove the front foot: 步骤 4 中的图像 1,3 HP 15-ef RAM Replacement, Remove the front foot: 步骤 4 中的图像 2,3 HP 15-ef RAM Replacement, Remove the front foot: 步骤 4 中的图像 3,3
      • Peel the front foot away from the back cover and remove it.
      询问修复机器人
      添加评论
    4. HP 15-ef RAM Replacement, Remove the rear foot: 步骤 5 中的图像 1,3 HP 15-ef RAM Replacement, Remove the rear foot: 步骤 5 中的图像 2,3 HP 15-ef RAM Replacement, Remove the rear foot: 步骤 5 中的图像 3,3
      • Use an opening pick to peel up an end of the rear rubber foot until you can grip it with your fingers.
      • Peel the rear foot away from the back cover and remove it.
      询问修复机器人
      添加评论
    5. HP 15-ef RAM Replacement, Reassembly information: 步骤 6 中的图像 1,3 HP 15-ef RAM Replacement, Reassembly information: 步骤 6 中的图像 2,3 HP 15-ef RAM Replacement, Reassembly information: 步骤 6 中的图像 3,3
      在这个步骤中使用的工具:
      Tesa 61395 Tape
      $8.95
      • Note that the rubber feet are different:
      • The rear foot is thicker, with a deeper recess.
      • The front foot is thinner, with a shallower recess.
      • During reassembly:
      • If you're reusing the rubber feet, the leftover adhesive should be tacky enough to reuse.
      • If the leftover adhesive isn't sticky enough or your replacement feet didn't come with adhesive, you can use double-sided tape such as Tesa Tape to secure the feet.
      • Make sure the strips of tape aren't wider than 6 mm, otherwise they may not fit.
      • To install a foot, remove its adhesive liner, lay the foot into its matching recess, and press down firmly along the entire length of the foot to secure it.
      添加评论
    1. HP 15-ef RAM Replacement, Unfasten the back cover: 步骤 7 中的图像 1,2 HP 15-ef RAM Replacement, Unfasten the back cover: 步骤 7 中的图像 2,2
      • Use a Phillips screwdriver to remove the eight screws securing the back cover:
      • Six 6.5 mm-long silver screws
      • Two 6.7 mm-long black screws
      • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the most snug into the screw head to avoid stripping it.
      询问修复机器人
      添加评论
    2. HP 15-ef RAM Replacement, Open your laptop: 步骤 8 中的图像 1,3 HP 15-ef RAM Replacement, Open your laptop: 步骤 8 中的图像 2,3 HP 15-ef RAM Replacement, Open your laptop: 步骤 8 中的图像 3,3
      • Flip your laptop over and open the screen.
      询问修复机器人
      添加评论
    3. HP 15-ef RAM Replacement, Release the clips: 步骤 9 中的图像 1,2 HP 15-ef RAM Replacement, Release the clips: 步骤 9 中的图像 2,2
      • Plastic clips secure the back cover to the frame. You'll hear and feel the clips release as you work.
      • Insert the flat side of an opening pick into the seam between the top left edge of the back cover and the frame.
      • Slide the opening pick down to the bottom left corner to release the clips on the left edge.
      询问修复机器人
      添加评论
    4. HP 15-ef RAM Replacement: 步骤 10 中的图像 1,2 HP 15-ef RAM Replacement: 步骤 10 中的图像 2,2
      • Avoid using excessive force when prying near the SD card slot, as it's a weak point in the case.
      • Insert the flat side of an opening pick into the seam between the top right edge of the back cover and the frame.
      • Slide the opening pick down to the bottom right corner to release the clips on the right edge.
      询问修复机器人
      添加评论
    5. HP 15-ef RAM Replacement: 步骤 11 中的图像 1,3 HP 15-ef RAM Replacement: 步骤 11 中的图像 2,3 HP 15-ef RAM Replacement: 步骤 11 中的图像 3,3
      • Insert the flat side of an opening pick between the bottom right corner of the back cover and frame.
      • Slide the opening pick to the bottom left corner to release the remaining clips.
      询问修复机器人
      添加评论
    6. HP 15-ef RAM Replacement, Flip your laptop over: 步骤 12 中的图像 1,3 HP 15-ef RAM Replacement, Flip your laptop over: 步骤 12 中的图像 2,3 HP 15-ef RAM Replacement, Flip your laptop over: 步骤 12 中的图像 3,3
      • Close the screen and flip your laptop back over again.
      询问修复机器人
      添加评论
    7. HP 15-ef RAM Replacement, Remove the back cover: 步骤 13 中的图像 1,3 HP 15-ef RAM Replacement, Remove the back cover: 步骤 13 中的图像 2,3 HP 15-ef RAM Replacement, Remove the back cover: 步骤 13 中的图像 3,3
      • Remove the back cover.
      • To reinstall the back cover, lay it on the frame and firmly press down around the perimeter to engage all of the clips.
      询问修复机器人
      添加评论
    1. HP 15-ef RAM Replacement, Unfasten the battery: 步骤 14 中的图像 1,2 HP 15-ef RAM Replacement, Unfasten the battery: 步骤 14 中的图像 2,2
      • Given the design of the battery connector, the only way to disconnect the battery is to physically remove it.
      • Try not to bend, crease, deform, poke, or puncture the battery with your tool—a damaged battery is a potential fire hazard.
      • Use a Phillips screwdriver to remove the five 3.7 mm-long screws securing the battery.
      询问修复机器人
      添加评论
    2. HP 15-ef RAM Replacement, Remove the battery: 步骤 15 中的图像 1,3 HP 15-ef RAM Replacement, Remove the battery: 步骤 15 中的图像 2,3 HP 15-ef RAM Replacement, Remove the battery: 步骤 15 中的图像 3,3
      • Gently lift the upper edge of the battery to disconnect its socket from the motherboard.
      • Remove the battery.
      • During reassembly, use the alignment posts to position the battery and press down on the socket to secure it.
      • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
      询问修复机器人
      添加评论
    1. HP 15-ef RAM Replacement, Unlatch the RAM: 步骤 16 中的图像 1,3 HP 15-ef RAM Replacement, Unlatch the RAM: 步骤 16 中的图像 2,3 HP 15-ef RAM Replacement, Unlatch the RAM: 步骤 16 中的图像 3,3
      • Your laptop has two memory slots, each with a pair of metal arms that secure a stick of RAM.
      • Simultaneously push out the metal arms on each side of a stick of RAM until they disengage and the stick pops up at a slight angle.
      询问修复机器人
      添加评论
    2. HP 15-ef RAM Replacement, Remove the RAM: 步骤 17 中的图像 1,2 HP 15-ef RAM Replacement, Remove the RAM: 步骤 17 中的图像 2,2
      • Pull the stick of RAM out of its socket to remove it.
      • Repeat for a second stick of RAM.
      • To install a memory module, insert it into its socket at a slight downward angle, then push down firmly until both metal arms lock the RAM in place.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
Spencer Day
于09/14/22注册
198,523 声望
创作了1,243篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了51,778篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 22
过去 30 天: 143
总计 2,159
