跳转到主内容
HP 15-R011DX Motherboard Replacement
Ethan Guillotte
Ethan Guillotte2 其他贡献者
最后更新于 January 22, 2021
15分钟
中等
The motherboard is the main hub for every component in a laptop. For this reason, one should always know how to access and disconnect any component from a motherboard. Removing a motherboard is also a necessary prerequisite to accessing components such as the RAM and CPU.
你所需要的
工具
  1. HP 15-R011DX Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 HP 15-R011DX Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Slide the lock mechanism on the left side of the laptop to the right.
  2. HP 15-R011DX Motherboard Replacement: 步骤 2 中的图像 1,1
    • While holding the right slide mechanism, remove the battery from the laptop.
    • The battery is not pictured here because it is missing from this particular device.
  3. HP 15-R011DX Motherboard Replacement, How to Access the Internal Components of an HP 15-R011DX: 步骤 3 中的图像 1,2 HP 15-R011DX Motherboard Replacement, How to Access the Internal Components of an HP 15-R011DX: 步骤 3 中的图像 2,2
    • Flip the laptop over to reveal screw locations.
    • Use a metal spudger to remove the two rear rubber feet. There are screws hidden underneath them.
  4. HP 15-R011DX Motherboard Replacement: 步骤 4 中的图像 1,2 HP 15-R011DX Motherboard Replacement: 步骤 4 中的图像 2,2
    • Remove the twelve 5mm Phillips #1 screws on the back of the laptop.
  5. HP 15-R011DX Motherboard Replacement: 步骤 5 中的图像 1,2 HP 15-R011DX Motherboard Replacement: 步骤 5 中的图像 2,2
    • Remove the DVD drive from the laptop.
    • Remove the two 3 mm Phillips #1 screws underneath the DVD drive.
  6. HP 15-R011DX Motherboard Replacement: 步骤 6 中的图像 1,3 HP 15-R011DX Motherboard Replacement: 步骤 6 中的图像 2,3 HP 15-R011DX Motherboard Replacement: 步骤 6 中的图像 3,3
    • Flip the laptop and open.
    • Detach the keyboard by prying it free from the laptop using a spudger.
    • Do not completely remove the keyboard yet. It is still attached by a ribbon cable.
    • Disconnect the keyboard ribbon cable.
  7. HP 15-R011DX Motherboard Replacement: 步骤 7 中的图像 1,2 HP 15-R011DX Motherboard Replacement: 步骤 7 中的图像 2,2
    • Disconnect the two narrow ribbon cables to the left of the keyboard connection.
    • Remove five 4 mm Phillips #1 screws from the metal tray for the keyboard.
    • Pry open the plastic casing using a spudger.
    • If struggling to remove the plastic case, check that all screws have been removed.
  8. HP 15-R011DX Motherboard Replacement, Hard Drive: 步骤 8 中的图像 1,1
    • Remove two 5 mm Phillips #1 screws located at the base of the hard drive.
  9. HP 15-R011DX Motherboard Replacement: 步骤 9 中的图像 1,2 HP 15-R011DX Motherboard Replacement: 步骤 9 中的图像 2,2
    • Pull the hard drive upwards and away from the laptop.
    • The hard drive should disconnect from its port on the motherboard as shown in the second image.
  10. HP 15-R011DX Motherboard Replacement: 步骤 10 中的图像 1,1
    • Flip the hard drive over.
    • Remove the two 4 mm Phillips #1 screws from the base of the hard drive.
    • Remove the mounting brace (silver bracket) from the hard drive.
  11. HP 15-R011DX Motherboard Replacement, Motherboard: 步骤 11 中的图像 1,2 HP 15-R011DX Motherboard Replacement, Motherboard: 步骤 11 中的图像 2,2
    • Remove the remaining two 5 mm Philips #1 screws from the motherboard.
  12. HP 15-R011DX Motherboard Replacement: 步骤 12 中的图像 1,1
    • Remove the tape from the display connector attached to the motherboard.
    • Disconnect the display connector from the motherboard.
  13. HP 15-R011DX Motherboard Replacement: 步骤 13 中的图像 1,1
    • Remove one 4 mm Phillips #1 screw from the wireless chip.
    • Remove the wireless chip from the motherboard.
  14. HP 15-R011DX Motherboard Replacement: 步骤 14 中的图像 1,1
    • Remove two 5 mm Phillips #1 screws from the USB component connected to the motherboard.
    • Lift the USB component until the band connecting it to the motherboard lifts off of the laptop.
  15. HP 15-R011DX Motherboard Replacement: 步骤 15 中的图像 1,1
    • Slowly lift the motherboard out of the computer.
    • Be sure that the I/O ports on the left side of the motherboard are not stuck on the laptop frame.
    • Disconnect the power connector from the motherboard as shown in the image.
结论
3等其他人完成本指南。
Ethan Guillotte
于03/20/19注册
517 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 13
总计 661
