跳转到主内容
加入维修社区 - 创建账户
HP 15-R011DX Cooling Fan Replacement
你所需要的
    1. HP 15-R011DX Cooling Fan Replacement, Battery: 步骤 1 中的图像 1,2 HP 15-R011DX Cooling Fan Replacement, Battery: 步骤 1 中的图像 2,2
      • Slide the lock mechanism on the left side of the laptop to the right.
      询问修复机器人
      添加评论
    2. HP 15-R011DX Cooling Fan Replacement: 步骤 2 中的图像 1,1
      • While holding the right slide mechanism, remove the battery from the laptop.
      • The battery is not pictured here because it is missing from this particular device.
      询问修复机器人
      添加评论
    1. HP 15-R011DX Cooling Fan Replacement, How to Access the Internal Components of an HP 15-R011DX: 步骤 3 中的图像 1,2 HP 15-R011DX Cooling Fan Replacement, How to Access the Internal Components of an HP 15-R011DX: 步骤 3 中的图像 2,2
      • Flip the laptop over to reveal screw locations.
      • Use a metal spudger to remove the two rear rubber feet. There are screws hidden underneath them.
      询问修复机器人
      添加评论
    2. HP 15-R011DX Cooling Fan Replacement: 步骤 4 中的图像 1,2 HP 15-R011DX Cooling Fan Replacement: 步骤 4 中的图像 2,2
      • Remove the twelve 5mm Phillips #1 screws on the back of the laptop.
      询问修复机器人
      添加评论
    3. HP 15-R011DX Cooling Fan Replacement: 步骤 5 中的图像 1,2 HP 15-R011DX Cooling Fan Replacement: 步骤 5 中的图像 2,2
      • Remove the DVD drive from the laptop.
      • Remove the two 3 mm Phillips #1 screws underneath the DVD drive.
      添加评论
    4. HP 15-R011DX Cooling Fan Replacement: 步骤 6 中的图像 1,3 HP 15-R011DX Cooling Fan Replacement: 步骤 6 中的图像 2,3 HP 15-R011DX Cooling Fan Replacement: 步骤 6 中的图像 3,3
      • Flip the laptop and open.
      • Detach the keyboard by prying it free from the laptop using a spudger.
      • Do not completely remove the keyboard yet. It is still attached by a ribbon cable.
      • Disconnect the keyboard ribbon cable.
      询问修复机器人
      添加评论
    5. HP 15-R011DX Cooling Fan Replacement: 步骤 7 中的图像 1,2 HP 15-R011DX Cooling Fan Replacement: 步骤 7 中的图像 2,2
      • Disconnect the two narrow ribbon cables to the left of the keyboard connection.
      • Remove five 4 mm Phillips #1 screws from the metal tray for the keyboard.
      • Pry open the plastic casing using a spudger.
      • If struggling to remove the plastic case, check that all screws have been removed.
      添加评论
    1. HP 15-R011DX Cooling Fan Replacement, Hard Drive: 步骤 8 中的图像 1,1
      • Remove two 5 mm Phillips #1 screws located at the base of the hard drive.
      询问修复机器人
      添加评论
    2. HP 15-R011DX Cooling Fan Replacement: 步骤 9 中的图像 1,2 HP 15-R011DX Cooling Fan Replacement: 步骤 9 中的图像 2,2
      • Pull the hard drive upwards and away from the laptop.
      • The hard drive should disconnect from its port on the motherboard as shown in the second image.
      询问修复机器人
      添加评论
    3. HP 15-R011DX Cooling Fan Replacement: 步骤 10 中的图像 1,1
      • Flip the hard drive over.
      • Remove the two 4 mm Phillips #1 screws from the base of the hard drive.
      • Remove the mounting brace (silver bracket) from the hard drive.
      询问修复机器人
      添加评论
    1. HP 15-R011DX Cooling Fan Replacement, Motherboard: 步骤 11 中的图像 1,2 HP 15-R011DX Cooling Fan Replacement, Motherboard: 步骤 11 中的图像 2,2
      • Remove the remaining two 5 mm Philips #1 screws from the motherboard.
      询问修复机器人
      添加评论
    2. HP 15-R011DX Cooling Fan Replacement: 步骤 12 中的图像 1,1
      • Remove the tape from the display connector attached to the motherboard.
      • Disconnect the display connector from the motherboard.
      询问修复机器人
      添加评论
    3. HP 15-R011DX Cooling Fan Replacement: 步骤 13 中的图像 1,1
      • Remove one 4 mm Phillips #1 screw from the wireless chip.
      • Remove the wireless chip from the motherboard.
      询问修复机器人
      添加评论
    4. HP 15-R011DX Cooling Fan Replacement: 步骤 14 中的图像 1,1
      • Remove two 5 mm Phillips #1 screws from the USB component connected to the motherboard.
      • Lift the USB component until the band connecting it to the motherboard lifts off of the laptop.
      询问修复机器人
      添加评论
    5. HP 15-R011DX Cooling Fan Replacement: 步骤 15 中的图像 1,1
      • Slowly lift the motherboard out of the computer.
      • Be sure that the I/O ports on the left side of the motherboard are not stuck on the laptop frame.
      • Disconnect the power connector from the motherboard as shown in the image.
      询问修复机器人
      添加评论
    1. HP 15-R011DX Cooling Fan Replacement, Cooling Fan: 步骤 16 中的图像 1,1
      • The cooling fan assembly is located on the underside of the motherboard.
      • Using a Phillips #1 screwdriver, remove the three 5mm screws that secure the cooling fan assembly to the motherboard.
      询问修复机器人
      添加评论
    2. HP 15-R011DX Cooling Fan Replacement: 步骤 17 中的图像 1,1
      • Separate the cooling fan assembly from the motherboard and proceed to use the canned air to clean the inner pieces of the fan.
      • You can now clean the inner parts of the fan assembly or replace with a new assembly.
      添加评论
    3. HP 15-R011DX Cooling Fan Replacement: 步骤 18 中的图像 1,1
      • Before reconnecting the cooling fan assembly, make sure to properly apply thermal paste and touch the two connectors together when reassembling your laptop.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
UMass Dartmouth, Team S2-G4, Bailey Spring 2019 UMass Dartmouth, Team S2-G4, Bailey Spring 2019 的会员
UMASSD-BAILEY-S19S2G4
3 名成员
创作了48篇指南
1指南评论
It appears as though the jfan1 connection on the motherboard doesn’t have a plastic connector. I’ve bought a fan for this laptop to solve some overheating issues, but I can’t find anywhere to plug it in (I’m assuming that on similar models, the jfan1 connection would be the one to use). Is there any way that I can somehow plug my fan into this motherboard?
Brandon Peterson - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 25
总计 1,518
