跳转到主内容
加入维修社区 - 创建账户
HMD Pulse Battery Replacement
你所需要的
    1. HMD Pulse Battery Replacement, Prepare your phone for disassembly: 步骤 1 中的图像 1,1
      • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
      • Unplug all cables from your phone and completely power it down.
      询问修复机器人
      添加评论
    1. HMD Pulse Battery Replacement, Remove the SIM card tray: 步骤 2 中的图像 1,3 HMD Pulse Battery Replacement, Remove the SIM card tray: 步骤 2 中的图像 2,3 HMD Pulse Battery Replacement, Remove the SIM card tray: 步骤 2 中的图像 3,3
      • Firmly press a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the left edge of your phone until the tray ejects.
      • Remove the SIM card tray.
      • During reassembly, use the tray's markings to orient and reinsert it properly.
      添加评论
    1. HMD Pulse Battery Replacement, Separate the back cover: 步骤 3 中的图像 1,2 HMD Pulse Battery Replacement, Separate the back cover: 步骤 3 中的图像 2,2
      • Insert the tip of an opening pick between the back cover and frame, at the SIM card tray cutout.
      添加评论
    2. HMD Pulse Battery Replacement: 步骤 4 中的图像 1,3 HMD Pulse Battery Replacement: 步骤 4 中的图像 2,3 HMD Pulse Battery Replacement: 步骤 4 中的图像 3,3
      • Position the opening pick straight down and slide it along the left edge to begin unclipping the back cover.
      询问修复机器人
      添加评论
    3. HMD Pulse Battery Replacement: 步骤 5 中的图像 1,3 HMD Pulse Battery Replacement: 步骤 5 中的图像 2,3 HMD Pulse Battery Replacement: 步骤 5 中的图像 3,3
      • Continue sliding the pick around the perimeter of your phone until the back cover is fully unclipped.
      • The corners can be tricky to unclip and may take some force. If you're having trouble, try prying up with the pick.
      • Don't try to fully remove the cover yet, as a delicate cable still connects it to your phone.
      询问修复机器人
      添加评论
    4. HMD Pulse Battery Replacement: 步骤 6 中的图像 1,3 HMD Pulse Battery Replacement: 步骤 6 中的图像 2,3 HMD Pulse Battery Replacement: 步骤 6 中的图像 3,3
      • Carefully flip your phone over so the back cover is facing up.
      • Lift the back cover off the frame and flip it over the left edge of your phone, laying the cover flat on your work surface.
      • Be very careful not to strain the back cover's delicate cable.
      • During reassembly, place the back cover onto the frame and firmly squeeze around the perimeter to reengage all the clips.
      询问修复机器人
      添加评论
    5. HMD Pulse Battery Replacement, Remove the motherboard cover: 步骤 7 中的图像 1,2 HMD Pulse Battery Replacement, Remove the motherboard cover: 步骤 7 中的图像 2,2
      在这个步骤中使用的工具:
      • Be very careful not to puncture the battery with your screwdriver.
      • Use a Phillips screwdriver to remove the nine 3.6 mm‑long screws securing the motherboard cover.
      • The screw near the center of the top edge is covered by a sticker. Pierce through it with your screwdriver, or use tweezers to remove it.
      询问修复机器人
      添加评论
    6. HMD Pulse Battery Replacement: 步骤 8 中的图像 1,3 HMD Pulse Battery Replacement: 步骤 8 中的图像 2,3 HMD Pulse Battery Replacement: 步骤 8 中的图像 3,3
      • Insert an opening pick between the right edge of the motherboard cover and frame.
      • Twist the pick to fully unclip the cover.
      询问修复机器人
      添加评论
    7. HMD Pulse Battery Replacement: 步骤 9 中的图像 1,2 HMD Pulse Battery Replacement: 步骤 9 中的图像 2,2
      • Remove the motherboard shield and its connected graphite sheet.
      • During reassembly, set the motherboard shield into place and press down firmly around the perimeter to reengage the clips.
      询问修复机器人
      添加评论
    8. HMD Pulse Battery Replacement, Disconnect the battery: 步骤 10 中的图像 1,2 HMD Pulse Battery Replacement, Disconnect the battery: 步骤 10 中的图像 2,2
      • Use the flat end of a spudger to pry up and disconnect the battery press connector from the bottom edge of the motherboard.
      • To reconnect these type of connectors, align the connector over its socket and press down with your fingertip—first at one side, then the other—until it clicks into place. Don't try to force the connector into place, or you may permanently damage it.
      询问修复机器人
      添加评论
    9. HMD Pulse Battery Replacement, Remove the back cover: 步骤 11 中的图像 1,2 HMD Pulse Battery Replacement, Remove the back cover: 步骤 11 中的图像 2,2
      • Use the flat end of a spudger to pry up and disconnect the back cover press connector from the bottom edge of the motherboard.
      询问修复机器人
      添加评论
    10. HMD Pulse Battery Replacement: 步骤 12 中的图像 1,1
      • Remove the back cover.
      询问修复机器人
      添加评论
    1. HMD Pulse Battery Replacement, Remove the battery: 步骤 13 中的图像 1,3 HMD Pulse Battery Replacement, Remove the battery: 步骤 13 中的图像 2,3 HMD Pulse Battery Replacement, Remove the battery: 步骤 13 中的图像 3,3
      • Be very careful not to bend, crease, or puncture the battery during the next few steps. A damaged battery can leak dangerous chemicals and catch fire.
      • Use your fingers to carefully peel the three plastic tabs from the left side of the battery.
      询问修复机器人
      添加评论
    2. HMD Pulse Battery Replacement: 步骤 14 中的图像 1,3 HMD Pulse Battery Replacement: 步骤 14 中的图像 2,3 HMD Pulse Battery Replacement: 步骤 14 中的图像 3,3
      • With one hand, fold the clear outer tabs out of the way of the battery and firmly hold them down to secure the frame.
      • If you're having trouble with the tabs, you can fold them under the phone and tape them to the screen.
      • With your free hand, grip the green center pull tab and pull straight up to fully separate the battery adhesive.
      • Lay the battery over the right edge of your phone.
      询问修复机器人
      添加评论
    3. HMD Pulse Battery Replacement: 步骤 15 中的图像 1,2 HMD Pulse Battery Replacement: 步骤 15 中的图像 2,2
      • Use your fingers to peel the battery's plastic film from the frame.
      询问修复机器人
      添加评论
    4. HMD Pulse Battery Replacement: 步骤 16 中的图像 1,2 HMD Pulse Battery Replacement: 步骤 16 中的图像 2,2
      在这个步骤中使用的工具:
      • Remove the battery and its film.
      • During reassembly:
      • Never reuse a deformed or damaged battery, as it's a potential safety hazard. Replace it with a new battery.
      • Use a spudger and tweezers to peel up and remove the two pieces of battery adhesive.
      • Apply the new adhesive to the frame and remove the plastic liners.
      • Firmly press the battery into its recess so the cable is on the top edge and the three tabs are on the left edge.
      询问修复机器人
      添加评论
结论
For optimal performance, calibrate your newly installed battery after reassembling your phone.
取消:我没有完成这个指南。
Spencer Day
于09/14/22注册
199,518 声望
创作了1,243篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了70,339篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 18
过去 30 天: 85
总计 3,436
