跳转到主内容
加入维修社区 - 创建账户
Google Pixel Watch 4 Screen Replacement
你所需要的
  1. Google Pixel Watch 4 Screen Replacement, Prepare your watch for disassembly: 步骤 1 中的图像 1,3 Google Pixel Watch 4 Screen Replacement, Prepare your watch for disassembly: 步骤 1 中的图像 2,3 Google Pixel Watch 4 Screen Replacement, Prepare your watch for disassembly: 步骤 1 中的图像 3,3
    • Before starting your repair:
    • Remove your watch from the charger.
    • Press and hold the crown button, then tap Power off to shut down your watch.
  2. Google Pixel Watch 4 Screen Replacement, Remove the watch bands: 步骤 2 中的图像 1,3 Google Pixel Watch 4 Screen Replacement, Remove the watch bands: 步骤 2 中的图像 2,3 Google Pixel Watch 4 Screen Replacement, Remove the watch bands: 步骤 2 中的图像 3,3
    • Remove each watch band by depressing the release button and sliding the band out of its groove.
  3. Google Pixel Watch 4 Screen Replacement: 步骤 3 中的图像 1,1
    • Throughout the rest of your repair, consider placing your watch on something soft like a clean cloth to help stabilize it and prevent scratches to the front glass.
  4. Google Pixel Watch 4 Screen Replacement, Remove the back sensor glass screws: 步骤 4 中的图像 1,3 Google Pixel Watch 4 Screen Replacement, Remove the back sensor glass screws: 步骤 4 中的图像 2,3 Google Pixel Watch 4 Screen Replacement, Remove the back sensor glass screws: 步骤 4 中的图像 3,3
    • Use a Torx Plus 2IP screwdriver to remove the 3.0 mm‑long screw from both watch band grooves (two screws total).
    • Both screws have a tiny O‑ring. If they don't lift away with the screw, use a pair of tweezers to carefully remove them from the band groove and set them aside. These O-rings are required to maintain waterproofing.
    • Handle these O-rings carefully. Avoid pinching or slicing them with your tool.
    • During reassembly:
    • Make sure the O‑rings are on the screws before installing them.
    • Push down firmly on the back glass while installing the screws to make sure the glass gets properly seated.
    • If there's a gap between the back glass and frame, remove the screws and reinstall them.
  5. Google Pixel Watch 4 Screen Replacement, Separate the back sensor glass: 步骤 5 中的图像 1,2 Google Pixel Watch 4 Screen Replacement, Separate the back sensor glass: 步骤 5 中的图像 2,2
    • Insert the point of a spudger (or a clean fingernail) into the seam between the back sensor glass and frame and pry up until the cover detaches.
  6. Google Pixel Watch 4 Screen Replacement, Reposition the back sensor glass: 步骤 6 中的图像 1,3 Google Pixel Watch 4 Screen Replacement, Reposition the back sensor glass: 步骤 6 中的图像 2,3 Google Pixel Watch 4 Screen Replacement, Reposition the back sensor glass: 步骤 6 中的图像 3,3
    • Gently lift the back glass and flip it over the side of the watch opposite the crown.
    • Be careful not to strain the cable connecting the back sensor glass.
  7. Google Pixel Watch 4 Screen Replacement, Remove the vibration motor screws: 步骤 7 中的图像 1,2 Google Pixel Watch 4 Screen Replacement, Remove the vibration motor screws: 步骤 7 中的图像 2,2
    • Optionally, you can disconnect the back glass to give you more room to work—though you can complete the repair just fine with it still connected.
    • Use a Torx Plus 2IP screwdriver to remove the two 2.2 mm‑long screws securing the vibration motor.
  8. Google Pixel Watch 4 Screen Replacement, Remove the vibration motor: 步骤 8 中的图像 1,2 Google Pixel Watch 4 Screen Replacement, Remove the vibration motor: 步骤 8 中的图像 2,2
  9. Google Pixel Watch 4 Screen Replacement, Reposition the back sensor glass: 步骤 9 中的图像 1,3 Google Pixel Watch 4 Screen Replacement, Reposition the back sensor glass: 步骤 9 中的图像 2,3 Google Pixel Watch 4 Screen Replacement, Reposition the back sensor glass: 步骤 9 中的图像 3,3
    • Gently flip the back sensor glass over the crown-side of the watch.
  10. Google Pixel Watch 4 Screen Replacement, Disconnect the battery: 步骤 10 中的图像 1,2 Google Pixel Watch 4 Screen Replacement, Disconnect the battery: 步骤 10 中的图像 2,2
    • Use the point of a spudger to pry up and disconnect the battery press connector.
    • During reassembly, use the point of a spudger to press down and reconnect the press connector.
    • This can be tricky, and may take a few tries.
    • If you're having trouble, loosen the two battery screws and reposition the connector. Once connected, re-tighten the battery screws.
  11. Google Pixel Watch 4 Screen Replacement, Remove the battery screws: 步骤 11 中的图像 1,2 Google Pixel Watch 4 Screen Replacement, Remove the battery screws: 步骤 11 中的图像 2,2
    • Use a Torx Plus 2IP screwdriver to remove the two 2.2 mm‑long screws securing the battery.
  12. Google Pixel Watch 4 Screen Replacement, Remove the battery: 步骤 12 中的图像 1,3 Google Pixel Watch 4 Screen Replacement, Remove the battery: 步骤 12 中的图像 2,3 Google Pixel Watch 4 Screen Replacement, Remove the battery: 步骤 12 中的图像 3,3
    • Remove the battery.
  13. Google Pixel Watch 4 Screen Replacement, Remove the screen cable bracket screws: 步骤 13 中的图像 1,2 Google Pixel Watch 4 Screen Replacement, Remove the screen cable bracket screws: 步骤 13 中的图像 2,2
    • Use a Torx Plus 1IP screwdriver to remove the two 2.0 mm‑long screws seucuring the screen cable bracket.
  14. Google Pixel Watch 4 Screen Replacement, Remove the screen cable bracket: 步骤 14 中的图像 1,3 Google Pixel Watch 4 Screen Replacement, Remove the screen cable bracket: 步骤 14 中的图像 2,3 Google Pixel Watch 4 Screen Replacement, Remove the screen cable bracket: 步骤 14 中的图像 3,3
    • Use tweezers to flip the bracket up and slowly peel it off the connector, being careful not to damage the tape.
    • During reassembly, apply the tape to the outer press connector before flipping the bracket over and into place.
  15. Google Pixel Watch 4 Screen Replacement, Disconnect the screen cable: 步骤 15 中的图像 1,3 Google Pixel Watch 4 Screen Replacement, Disconnect the screen cable: 步骤 15 中的图像 2,3 Google Pixel Watch 4 Screen Replacement, Disconnect the screen cable: 步骤 15 中的图像 3,3
    • Insert the flat end of a spudger into the gap in the two screen cable press connectors.
    • Twist the spudger to disconnect the cables.
    • During reassembly, line the press connectors up and pinch them together to connect them.
  16. Google Pixel Watch 4 Screen Replacement, Reposition the back sensor glass: 步骤 16 中的图像 1,2 Google Pixel Watch 4 Screen Replacement, Reposition the back sensor glass: 步骤 16 中的图像 2,2
    • Gently flip the back glass over the side of the watch opposite the crown.
  17. Google Pixel Watch 4 Screen Replacement, Remove the screen screws: 步骤 17 中的图像 1,2 Google Pixel Watch 4 Screen Replacement, Remove the screen screws: 步骤 17 中的图像 2,2
    • Remove the four screws securing the display:
    • One 5.1 mm‑long Torx Plus 2IP screw
    • Two 3.3 mm‑long Torx Plus 2IP screws
    • One 4.2 mm‑long Torx Plus 5IP standoff screw
    • During reassembly, push down on the frame while installing the screws to make sure they're threading into their holes on the display.
  18. Google Pixel Watch 4 Screen Replacement, Move the back sensor glass and flip over the watch: 步骤 18 中的图像 1,3 Google Pixel Watch 4 Screen Replacement, Move the back sensor glass and flip over the watch: 步骤 18 中的图像 2,3 Google Pixel Watch 4 Screen Replacement, Move the back sensor glass and flip over the watch: 步骤 18 中的图像 3,3
    • Flip the back sensor glass into place and flip your watch over so the screen faces up.
  19. Google Pixel Watch 4 Screen Replacement, Separate the screen: 步骤 19 中的图像 1,2 Google Pixel Watch 4 Screen Replacement, Separate the screen: 步骤 19 中的图像 2,2
    • Insert the flat end of a spudger in the seam between the screen and frame and twist the spudger to separate the screen.
    • The display seals with an O-ring and might "pop" up once released.
  20. Google Pixel Watch 4 Screen Replacement, Remove the screen: 步骤 20 中的图像 1,3 Google Pixel Watch 4 Screen Replacement, Remove the screen: 步骤 20 中的图像 2,3 Google Pixel Watch 4 Screen Replacement, Remove the screen: 步骤 20 中的图像 3,3
    • Lift the display up and carefully guide the screen cable out of its cutout to remove the screen.
    • During reassembly, feed the screen cable through its cutout until you can grip it with your fingers on the opposite side, then gently pull it through.
  21. Google Pixel Watch 4 Screen Replacement, O-ring installation: 步骤 21 中的图像 1,3 Google Pixel Watch 4 Screen Replacement, O-ring installation: 步骤 21 中的图像 2,3 Google Pixel Watch 4 Screen Replacement, O-ring installation: 步骤 21 中的图像 3,3
    • If you plan to reuse the existing O-ring, be gentle when handling it—especially with sharp tweezers. Even a small indent may compromise the watch's water and dust resistance.
    • Use a pair of tweezers to remove the screen O‑ring—it will either be stuck to the frame or the underside of the screen.
    • If the O‑ring's groove is dirty or has gunk built up, apply a few drops of high‑concentration (>90%) isopropyl alcohol to a cotton swab and wipe it clean.
    • Avoid applying isopropyl alcohol to the magnetic strip on the side opposite the crown.
    • Place the new O‑ring loosely onto its lip on the frame.
    • Optionally, coat the O-ring in a small amount of O-ring-specific grease during installation.
    • Use your fingers to hold the O-ring in place and use a spudger to slide the opposite side up and over the lip until it seats in its groove.
    • Make sure the entire O‑ring is properly seated in its groove before continuing reassembly.
结论
另外一个人完成了本指南。
Spencer Day
于09/14/22注册
160,009 声望
创作了1,045篇指南
2指南评论
Any idea when the replacement screens will be available to purchase?
nathan - 回复
When will the parts be available?
JR1 - 回复
添加评论
浏览统计数据:
过去 24 小时: 33
过去 7 天: 238
过去 30 天: 1,379
总计 6,418
