跳转到主内容
加入维修社区 - 创建账户
Google Pixel 9 Pro XL Rear Cover Replacement
你所需要的
  1. Google Pixel 9 Pro XL Rear Cover Replacement, Safety precautions: 步骤 1 中的图像 1,2 Google Pixel 9 Pro XL Rear Cover Replacement, Safety precautions: 步骤 1 中的图像 2,2
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables and completely power down your phone.
    询问修复机器人
  2. Google Pixel 9 Pro XL Rear Cover Replacement, Adhesive information: 步骤 2 中的图像 1,3 Google Pixel 9 Pro XL Rear Cover Replacement, Adhesive information: 步骤 2 中的图像 2,3 Google Pixel 9 Pro XL Rear Cover Replacement, Adhesive information: 步骤 2 中的图像 3,3
    • Adhesive secures the perimeter of the rear cover to the frame.
    • When separating the adhesive, don't insert your tool more than 3 mm under the rear cover to avoid damaging the internal components.
    • Measure 3 mm from the tip and mark your opening pick with a permanent marker. Alternatively, you can tape a coin to a pick 3 mm from the tip.
    询问修复机器人
  3. Google Pixel 9 Pro XL Rear Cover Replacement, Apply a suction handle: 步骤 3 中的图像 1,2 Google Pixel 9 Pro XL Rear Cover Replacement, Apply a suction handle: 步骤 3 中的图像 2,2
    • Attach a suction handle to the bottom edge of the rear cover, as close to the edge as possible.
  4. Google Pixel 9 Pro XL Rear Cover Replacement, Insert an opening pick: 步骤 4 中的图像 1,3 Google Pixel 9 Pro XL Rear Cover Replacement, Insert an opening pick: 步骤 4 中的图像 2,3 Google Pixel 9 Pro XL Rear Cover Replacement, Insert an opening pick: 步骤 4 中的图像 3,3
    • Pull up on the suction handle with strong, steady force to create a small gap under the rear cover.
    • Insert the tip of an opening pick in the gap.
    询问修复机器人
  5. Google Pixel 9 Pro XL Rear Cover Replacement, Separate the rear cover adhesive: 步骤 5 中的图像 1,3 Google Pixel 9 Pro XL Rear Cover Replacement, Separate the rear cover adhesive: 步骤 5 中的图像 2,3 Google Pixel 9 Pro XL Rear Cover Replacement, Separate the rear cover adhesive: 步骤 5 中的图像 3,3
    • Slide your opening pick along the bottom edge to separate the adhesive securing it.
    • Remember: don't insert the opening pick deeper than 3 mm.
    询问修复机器人
  6. Google Pixel 9 Pro XL Rear Cover Replacement: 步骤 6 中的图像 1,3 Google Pixel 9 Pro XL Rear Cover Replacement: 步骤 6 中的图像 2,3 Google Pixel 9 Pro XL Rear Cover Replacement: 步骤 6 中的图像 3,3
    • Slide your opening pick up the left edge and along the top edge to separate the adhesive.
    询问修复机器人
  7. Google Pixel 9 Pro XL Rear Cover Replacement: 步骤 7 中的图像 1,3 Google Pixel 9 Pro XL Rear Cover Replacement: 步骤 7 中的图像 2,3 Google Pixel 9 Pro XL Rear Cover Replacement: 步骤 7 中的图像 3,3
    • Slide your pick down the right edge to separate the remaining adhesive.
    询问修复机器人
  8. Google Pixel 9 Pro XL Rear Cover Replacement, Prop up the rear cover: 步骤 8 中的图像 1,3 Google Pixel 9 Pro XL Rear Cover Replacement, Prop up the rear cover: 步骤 8 中的图像 2,3 Google Pixel 9 Pro XL Rear Cover Replacement, Prop up the rear cover: 步骤 8 中的图像 3,3
    • Don't try to fully remove the rear cover yet, as a ribbon cable on the right edge connects it to the phone.
    • Use the suction handle to lift the left edge of the rear cover and swing it over the right edge, like opening the cover of a book.
    • If you're having trouble, check the perimeter for any remaining adhesive and use your opening pick to separate it.
    • Prop up the rear cover with the suction handle so you can access the ribbon cable near the top right corner.
    询问修复机器人
  9. Google Pixel 9 Pro XL Rear Cover Replacement, Remove the cable cover: 步骤 9 中的图像 1,2 Google Pixel 9 Pro XL Rear Cover Replacement, Remove the cable cover: 步骤 9 中的图像 2,2
    • Use a Torx Plus 3IP screwdriver to remove the two 5.2 mm‑long screws securing the cable cover.
    询问修复机器人
  10. Google Pixel 9 Pro XL Rear Cover Replacement: 步骤 10 中的图像 1,2 Google Pixel 9 Pro XL Rear Cover Replacement: 步骤 10 中的图像 2,2
    • Use tweezers or your fingers to remove the cable cover.
    询问修复机器人
  11. Google Pixel 9 Pro XL Rear Cover Replacement, Disconnect the rear cover: 步骤 11 中的图像 1,3 Google Pixel 9 Pro XL Rear Cover Replacement, Disconnect the rear cover: 步骤 11 中的图像 2,3 Google Pixel 9 Pro XL Rear Cover Replacement, Disconnect the rear cover: 步骤 11 中的图像 3,3
    • Use the point of a spudger to pry up and disconnect the rear cover press connector.
    询问修复机器人
  12. Google Pixel 9 Pro XL Rear Cover Replacement, Remove the rear cover: 步骤 12 中的图像 1,1
    • Remove the rear cover.
    • During reassembly, follow this guide to apply new adhesive and install your back cover.
    询问修复机器人
结论
To reassemble your device, follow this guide.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
8等其他人完成本指南。
Spencer Day
于09/14/22注册
187,948 声望
创作了1,187篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了25,707篇指南
5指南评论
User Torx Plus 3IP screwdriver? I don't find the screwdriver anywhere . Can I use one screw from this toolkit? If so, which one? - Essential Electronics Toolkit
Ram A - 回复 分享
Hi Ram. The Torx Plus 3IP bit (not driver) and many other bits are available here on our site. We also have drivers, in both aluminum and plastic.
Spencer Day - 回复 分享
Does the rear cover come with glue? Or I have to buy the separately?
Bruno Llangostera Prats - 回复 分享
ifixit's instructions that show a suction cup to remove a screen or a glass back always assume your glass is intact. I would assume most often it is shattered so forget using a suction cup. I used some thick shipping tape to cover the broken glass which gives the suction cup a chance to hold.
Scott Z - 回复 分享
Easy guide to follow. I was able to replace my back glass due to the camera bar separating from the glass. Thank you!
David Z - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 15
过去 7 天: 94
过去 30 天: 426
总计 7,519
