跳转到主内容
GoPro Karma Arms Replacement
你所需要的
  1. GoPro Karma Arms Replacement, Battery: 步骤 1 中的图像 1,1
    • Hook your fingers on the tab and pull out the battery.
  2. GoPro Karma Arms Replacement, Stabilizer: 步骤 2 中的图像 1,3 GoPro Karma Arms Replacement, Stabilizer: 步骤 2 中的图像 2,3 GoPro Karma Arms Replacement, Stabilizer: 步骤 2 中的图像 3,3
    • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
    • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
  3. GoPro Karma Arms Replacement: 步骤 3 中的图像 1,1
    • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
  4. GoPro Karma Arms Replacement, Landing Gear: 步骤 4 中的图像 1,1
    • Flip the drone upside down with the landing gear out.
    • Remove the four 1.2 cm long hex screws with a Hex 2.0 screwdriver in the four corners of the landing gear
  5. GoPro Karma Arms Replacement: 步骤 5 中的图像 1,1
    • Push with your thumb and pull up with your fingers to remove the landing gear.
    • Caution: The landing gear is connected by a thin cable so do not pull too far away.
  6. GoPro Karma Arms Replacement: 步骤 6 中的图像 1,2 GoPro Karma Arms Replacement: 步骤 6 中的图像 2,2
    • Flip over the landing gear and locate the cable connector.
    • Use your thumbnail to disconnect the cable and free the landing gear.
  7. GoPro Karma Arms Replacement, Arms: 步骤 7 中的图像 1,1
    • Remove the two 1.2 cm long hex screws with a Hex 2.0 screwdriver and set them aside.
  8. GoPro Karma Arms Replacement: 步骤 8 中的图像 1,2 GoPro Karma Arms Replacement: 步骤 8 中的图像 2,2
    • Remove both locked connectors by pushing the connector release tool into the hole in the center and pulling up with the white handles.
    • The connector release tool is only included with the purchase of a replacement arm from the GoPro website.
    • If you do not have a connector release tool, use a small screwdriver to push each tab while pulling up with the white handles.
  9. GoPro Karma Arms Replacement: 步骤 9 中的图像 1,3 GoPro Karma Arms Replacement: 步骤 9 中的图像 2,3 GoPro Karma Arms Replacement: 步骤 9 中的图像 3,3
    • Remove the cover plate by pulling up on the side.
    • Feed each connector through the hole and set aside the cover plate.
  10. GoPro Karma Arms Replacement: 步骤 10 中的图像 1,2 GoPro Karma Arms Replacement: 步骤 10 中的图像 2,2
    • Loosen the 2 cm long hex screw in the arm with a Hex 2.0 screwdriver.
    • The screw will not come out but loosen it until it can rotate easily.
    • Pull up and off the broken arm.
结论
另外一个人完成了本指南。
Kyle Hoff
于04/23/18注册
141 声望
撰写一个指南
团队
Cal Poly, Team S25-G14, Maness Spring 2018 Cal Poly, Team S25-G14, Maness Spring 2018 的会员
CPSU-MANESS-S18S25G14
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 13
总计 1,970
