跳转到主内容
Gateway Solo 1200 Battery Replacement
Addison
Addison4 其他贡献者
最后更新于 October 15, 2020
1分钟
非常容易
Follow this replacement guide to replace an old or faulty battery.
Your Gateway Solo 1200’s battery will normally lose its ability to hold the maximum capacity over time as it ages. If your laptop can still use and charge the battery, but the battery life or capacity has shrunk down to a quarter of its original capacity, you should consider replacing your laptop battery. Removing your laptop’s battery is also an important prerequisite to replacing electrical components inside your laptop.
Never work on anything that is plugged into a power outlet. The device should be physically unplugged, not just switched off.
  1. Gateway Solo 1200 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Gateway Solo 1200 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Gateway Solo 1200 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Turn off your laptop and disconnect it from AC Adapter before use.
    • Locate the battery latch on the bottom of the laptop.
    • Release the latch by pressing it with your thumb and sliding it to the right.
    • Slide the battery out of its compartment.
    • Discharge your laptop by pushing the power button after removing the battery.
结论
另外一个人完成了本指南。
Addison
于08/30/19注册
3,024 声望
创作了17篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 23
总计 390
