跳转到主内容
Gateway NV52 Hard Drive Compartment Replacement
Tim En
Tim En4 其他贡献者
最后更新于 July 27, 2020
5分钟
非常容易
Access to the Hard Drive Compartment will require some tool work.
你所需要的
工具
  1. Gateway NV52 Hard Drive Compartment Replacement, Base Cover: 步骤 1 中的图像 1,1
    • Remove the five identical 3/16" Phillips screws that secures the hard drive and memory cover using a Phillips #0 Screwdriver.
  2. Gateway NV52 Hard Drive Compartment Replacement: 步骤 2 中的图像 1,1
    • Lift up the base cover from the the top with your hands to a 90 degree angle.
    • Remove the base cover and place it in a safe and dry place.
  3. Gateway NV52 Hard Drive Compartment Replacement, Hard Drive Compartment: 步骤 3 中的图像 1,1
    • Remove the 1/4" Phillip screw located at the top right of the Hard Drive using a Phillips #0 Screwdriver .
  4. Gateway NV52 Hard Drive Compartment Replacement: 步骤 4 中的图像 1,3 Gateway NV52 Hard Drive Compartment Replacement: 步骤 4 中的图像 2,3 Gateway NV52 Hard Drive Compartment Replacement: 步骤 4 中的图像 3,3
    • Remove the Hard Drive component from its compartment. To do so, slide the component downward away from the battery pack.
    • Lift the Hard Drive to a 90 degree angle and out of its slot.
    • Place the Hard Drive in a designated zone.
结论
2等其他人完成本指南。
Tim En
于01/26/13注册
557 声望
创作了4篇指南
团队
Cal Poly, Team 7-24, Regan Spring 2014 Cal Poly, Team 7-24, Regan Spring 2014 的会员
CPSU-REGAN-S14S7G24
4 名成员
创作了18篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 15
总计 1,049
