跳转到主内容
加入维修社区 - 创建账户
Garmin Vivoactive Motherboard Replacement
你所需要的
    1. Garmin Vivoactive Motherboard Replacement, Wristband: 步骤 1 中的图像 1,1
      • Hold the the metal screwdriver, with a T5 Torx bit, in your dominant hand.
      • Hold the rubber screwdriver, with a Hex T6 Torx bit, in your other hand.
      • While holding the rubber screwdriver in place, simultaneously unscrew the pin (counterclockwise) with the metal screwdriver in your dominant hand.
      询问修复机器人
      添加评论
    2. Garmin Vivoactive Motherboard Replacement: 步骤 2 中的图像 1,2 Garmin Vivoactive Motherboard Replacement: 步骤 2 中的图像 2,2
      • Once the 1mm screw is removed, reinsert the metal screwdriver in that same hole.
      • Gently push the strap's pin out. It will begin to protrude from the other end.
      • Use your fingers to grab the exposed pin and slide it free. The strap should now be disconnected from the device.
      询问修复机器人
      添加评论
    1. Garmin Vivoactive Motherboard Replacement, Display Unit: 步骤 3 中的图像 1,1
      • Place a heated iOpener over the display to loosen the adhesive.
      • After about a minute, the iOpener may be removed.
      • For more in depth instructions on using the iOpener, refer to the iOpener guide.
      询问修复机器人
      添加评论
    2. Garmin Vivoactive Motherboard Replacement: 步骤 4 中的图像 1,2 Garmin Vivoactive Motherboard Replacement: 步骤 4 中的图像 2,2
      • Place the blue plastic opening tool in-between the screen and plastic casing of the watch and slowly pry up one side of the screen.
      询问修复机器人
      添加评论
    3. Garmin Vivoactive Motherboard Replacement: 步骤 5 中的图像 1,1
      • Once the first side has come free, wedge the blue pick in between the screen and watch unit on that side.
      • Complete one pass around the perimeter of the screen to break the adhesive bond on all four sides.
      • Insert it a minimal distance to avoid damaging internal components.
      询问修复机器人
      添加评论
    4. Garmin Vivoactive Motherboard Replacement: 步骤 6 中的图像 1,1
      • Use the blue plastic opening tool to pry up the side of the glass. Raise it to a point where your fingernail can fit in the gap.
      • Do the same on the opposite side of the device until you have a good grip of the screen.
      询问修复机器人
      添加评论
    5. Garmin Vivoactive Motherboard Replacement: 步骤 7 中的图像 1,1
      • Obtain a careful grip of the screen from two of its sides.
      • Slowly lift the screen off of the case. Separate it just enough so as not to damage the connection to the motherboard.
      询问修复机器人
      添加评论
    6. Garmin Vivoactive Motherboard Replacement: 步骤 8 中的图像 1,1
      • Detach the orange tab that connects the screen to the motherboard with a gentle uplift using a plastic opening tool.
      • Upon completing this step, the screen should be free from the rest of the device.
      添加评论
    1. Garmin Vivoactive Motherboard Replacement, Battery: 步骤 9 中的图像 1,2 Garmin Vivoactive Motherboard Replacement, Battery: 步骤 9 中的图像 2,2
      • Follow previous guides until you've exposed the battery as shown.
      • Begin by removing the battery connector tab.
      • Be sure not to use a metal implement or your fingers to remove this tab. Doing so may cause personal harm or damage to the electrical components.
      询问修复机器人
      添加评论
    2. Garmin Vivoactive Motherboard Replacement: 步骤 10 中的图像 1,2 Garmin Vivoactive Motherboard Replacement: 步骤 10 中的图像 2,2
      • Use a plastic opening pick to gently pry out the battery as shown.
      • The battery is Lithium Polymer, follow safe handling procedures and DO NOT deform it upon removal.
      询问修复机器人
      添加评论
    3. Garmin Vivoactive Motherboard Replacement: 步骤 11 中的图像 1,3 Garmin Vivoactive Motherboard Replacement: 步骤 11 中的图像 2,3 Garmin Vivoactive Motherboard Replacement: 步骤 11 中的图像 3,3
      • With the battery loose from the case, rotate it to expose the attached tab
      • Gently pry up the attached tab with a fingernail.
      • Keep the vibrator, circled in red, as you may need to solder it to the new battery upon re-installation later.
      添加评论
    1. Garmin Vivoactive Motherboard Replacement, Motherboard: 步骤 12 中的图像 1,2 Garmin Vivoactive Motherboard Replacement, Motherboard: 步骤 12 中的图像 2,2
      • Remove the four 2.4 mm screws with a PH00 Phillips head screwdriver.
      • Make an effort not to damage any nearby components of the motherboard with the screwdriver.
      询问修复机器人
      添加评论
    2. Garmin Vivoactive Motherboard Replacement: 步骤 13 中的图像 1,2 Garmin Vivoactive Motherboard Replacement: 步骤 13 中的图像 2,2
      • Use the spudger to pry up the board from the case.
      • Insert the spudger a minimum distance beneath the board as there are components below.
      • Wiggle the exposed side of the board from each end until it comes free.
      • Use proper electrostatic discharge safety when removing and handling the board.
      询问修复机器人
      添加评论
    3. Garmin Vivoactive Motherboard Replacement: 步骤 14 中的图像 1,2 Garmin Vivoactive Motherboard Replacement: 步骤 14 中的图像 2,2
      • Remove the GPS antenna by sliding it away from the board.
      • Keep track of the antenna and add it to the new board upon replacement.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
Cal Poly, Team 1-21, Maness Fall 2015 Cal Poly, Team 1-21, Maness Fall 2015 的会员
CPSU-MANESS-F15S1G21
4 名成员
创作了35篇指南
2指南评论
Any tips on where to buy a motherboard?
Breener - 回复 分享
Only <3 months, the motherboard is gone?
Do you have any service shop where I can mail for repairing? I am not going to mail order a motherboard and install by myself every 3 months.
Ming
Yong-Ming Yu - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 55
总计 15,084
