简介
After many cycles of charging and discharging, batteries become fatigued and lose their capacity to hold a charge. Manufacturing defects and improper storage can also lead to your watch battery not being as efficient as it once was. This straightforward guide will walk you through the steps of replacing your battery whatever the cause of its failure.
This procedure will fix any current problems you have with your battery. We also recommend you take the time to learn about proper charging and storage techniques to get the maximum life cycle out of your battery. Some of the basic steps points include:
- Store the device in a room temperature space out of direct sunlight
- Charge the device daily or at least every other day
- Do not let it discharge below 5%
Otherwise we hope this process goes well for you, good luck!
你所需要的
Hold the the metal screwdriver, with a T5 Torx bit, in your dominant hand.
Hold the rubber screwdriver, with a Hex T6 Torx bit, in your other hand.
While holding the rubber screwdriver in place, simultaneously unscrew the pin (counterclockwise) with the metal screwdriver in your dominant hand.
Place a heated iOpener over the display to loosen the adhesive.
After about a minute, the iOpener may be removed.
Follow previous guides until you've exposed the battery as shown.
Begin by removing the battery connector tab.
17等其他人完成本指南。
29指南评论
where to buy battery?
