跳转到主内容
加入维修社区 - 创建账户
Garmin StreetPilot c320 Battery Replacement
你所需要的
    1. Garmin StreetPilot c320 Battery Replacement, Rear Case Assembly: 步骤 1 中的图像 1,2 Garmin StreetPilot c320 Battery Replacement, Rear Case Assembly: 步骤 1 中的图像 2,2
      • Wedge a plastic opening tool in between the outer frame and the rear panel assembly.
      • Pry the outer frame off the perimeter of the rear panel assembly.
      • The cover will easily pop off.
      询问修复机器人
      添加评论
    2. Garmin StreetPilot c320 Battery Replacement: 步骤 2 中的图像 1,2 Garmin StreetPilot c320 Battery Replacement: 步骤 2 中的图像 2,2
      • Remove the four #00 Phillips screws securing the front case assembly to the rear case assembly.
      • Carefully lift, but do not completely separate, the front case assembly from the rear case assembly.
      • Be extremely cautious when separating both halves, as the rear case assembly is still attached to the front case assembly via a few connectors.
      询问修复机器人
      添加评论
    3. Garmin StreetPilot c320 Battery Replacement: 步骤 3 中的图像 1,1
      • Gently pull the battery cable connector from its socket on the motherboard.
      • The second connector can remain attached to the motherboard, but be careful not to break the connector while handling both halves of the device.
      询问修复机器人
      添加评论
    1. Garmin StreetPilot c320 Battery Replacement, Battery: 步骤 4 中的图像 1,1
      • Do not disconnect the black wire. Doing so may cause severe damage to your device.
      • Remove the two #00 Phillips screws securing the battery to the rear case assembly.
      询问修复机器人
      添加评论
    2. Garmin StreetPilot c320 Battery Replacement: 步骤 5 中的图像 1,2 Garmin StreetPilot c320 Battery Replacement: 步骤 5 中的图像 2,2
      • Use a plastic opening tool to peel back the battery bracket.
      • Cautiously grasp the battery and lift it out of the device.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
Cal Poly, Team 11-19, Maness Winter 2012 Cal Poly, Team 11-19, Maness Winter 2012 的会员
CPSU-MANESS-W12S11G19
4 名成员
创作了12篇指南
2指南评论
Where can I purchase a new Garmin StreetPilot c320 Battery Replacement battery?
john Lyons
11 Cavanaugh Cres
Terrace Bay Ontario
P0T2W0 Canada
John Lyons - 回复 分享
Thanks' - I just found two of my old Garmin StreetPilot c320 units in storage.
This will be the project of the evening watching movies.
New 18650 Battery with charging protection is ready.
Thankfully these are ten times easier than the TomTom just completed with new battery install.
Cheers
Philscbx - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 22
总计 2,891
