跳转到主内容
Game Boy Color Speaker Replacement
Finn Dooley
Finn Dooley 另一个贡献者
最后更新于 October 31, 2023
10 - 15 分钟
中等
社区贡献指南
The speakers on the device may become dirty or damaged by dust and dirt, requiring a cleaning or replacement. This guide will show you how to do both.
你所需要的
工具
查看更多...
  1. Game Boy Color Speaker Replacement, Battery: 步骤 1 中的图像 1,3 Game Boy Color Speaker Replacement, Battery: 步骤 1 中的图像 2,3 Game Boy Color Speaker Replacement, Battery: 步骤 1 中的图像 3,3
    • Remove any games in the system before beginning.
    • Press up on the battery holder tab on the back to lift it up and remove it
  2. Game Boy Color Speaker Replacement, Removing the back shell: 步骤 2 中的图像 1,2 Game Boy Color Speaker Replacement, Removing the back shell: 步骤 2 中的图像 2,2
    • Using a Y1 screwdriver, remove the six screws on the back of the device.
  3. Game Boy Color Speaker Replacement, Removing the motherboard: 步骤 3 中的图像 1,1
    • When reassembling, make sure to align the power switch with the corresponding piece of plastic inside the shell. If not aligned it will stop you from screwing it back together and will break if force is applied.
    • Don't yet unsolder the speaker, as you'll be unable to remove it until the motherboard comes off.
    • Remove the 3 PH0 Phillips screws near the bottom of the device.
  4. Game Boy Color Speaker Replacement, Display Ribbon Cable: 步骤 4 中的图像 1,3 Game Boy Color Speaker Replacement, Display Ribbon Cable: 步骤 4 中的图像 2,3 Game Boy Color Speaker Replacement, Display Ribbon Cable: 步骤 4 中的图像 3,3
    • Push up on the two dark grey pieces of plastic on the display ribbon cable bracket.
    • Make sure they are in a position similar to the one in the second image. Then they are fully extended.
    • Be very careful pushing on these as they are fragile and will break easily. If they do, the display cable will no longer be as secure and could have a bad connection.
  5. Game Boy Color Speaker Replacement: 步骤 5 中的图像 1,2 Game Boy Color Speaker Replacement: 步骤 5 中的图像 2,2
    • Using a spudger, screwdriver or other long thin object, gently pull the ribbon cable out of the bracket.
  6. Game Boy Color Speaker Replacement, Speaker: 步骤 6 中的图像 1,2 Game Boy Color Speaker Replacement, Speaker: 步骤 6 中的图像 2,2
    • If the speaker is simply dirty, clean it and the speaker holes in the case. Then, reassemble it and test the speakers. If they still don't work then continue on.
    • Once you've removed the motherboard, you are now free to desolder the speaker wires and replace it with a new one.
    • Make sure to keep the same polarity as the original, as otherwise it may sound a bit different. However, it likely doesn't matter and won't damage anything if the polarity is reversed.
结论
9等其他人完成本指南。
Finn Dooley
于03/09/22注册
359 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 30
过去 30 天: 119
总计 7,848
