跳转到主内容
加入维修社区 - 创建账户
Game Boy Advance Back Shell Replacement
浏览量: 1.4万
浏览统计数据:
过去24小时
7
过去 7 天:
49
过去 30 天:
174
总计
14,203
评论: 2
2 guide comments.
Go to guide comments
已完成: 5
5 人已将本指南标记为“已完成”。你会是下一个完成的人吗?
收藏: 5
5 人已收藏(并订阅)本指南。你会是下一个吗?
所需时间: 5分钟
难度: 简单
Follow this guide to replace, upgrade, or customize the back shell (aka rear shell or back cover) on your Nintendo Game Boy Advance model AGB-001.
If you're completely re‑shelling your Game Boy, follow this guide.
The Game Boy Advance uses JIS screws. If you use a non-iFixit Phillips driver in JIS screws, you'll risk stripping them. iFixit's Phillips bits are designed to be compatible with JIS screws.
你所需要的
工具
    1. Game Boy Advance Back Shell Replacement, Prepare your Game Boy for disassembly: 步骤 1 中的图像 1,2 Game Boy Advance Back Shell Replacement, Prepare your Game Boy for disassembly: 步骤 1 中的图像 2,2
      • Before working on your Game Boy, turn the power switch to the OFF position and unplug any cables.
      • If you have a game cartridge installed, remove it.
      • Since your Game Boy will be laying screen‑side down for most of your repair, consider placing it on a clean cloth for protection.
      询问修复机器人
      添加评论
    1. Game Boy Advance Back Shell Replacement, Remove the battery cover: 步骤 2 中的图像 1,3 Game Boy Advance Back Shell Replacement, Remove the battery cover: 步骤 2 中的图像 2,3 Game Boy Advance Back Shell Replacement, Remove the battery cover: 步骤 2 中的图像 3,3
      • Release the battery cover tab with your finger and swing the cover away from your Game Boy to remove it.
      • During reassembly, insert the tabs on the bottom edge of the cover into their cutouts and press the cover into place.
      询问修复机器人
      添加评论
    2. Game Boy Advance Back Shell Replacement, Remove the batteries: 步骤 3 中的图像 1,3 Game Boy Advance Back Shell Replacement, Remove the batteries: 步骤 3 中的图像 2,3 Game Boy Advance Back Shell Replacement, Remove the batteries: 步骤 3 中的图像 3,3
      • Remove the two AA batteries.
      • If the metal terminals are corroded, follow this guide to clean them.
      • When installing batteries, use the diagram in the battery well to properly orient them.
      询问修复机器人
      添加评论
    1. Game Boy Advance Back Shell Replacement, Remove the back shell screws: 步骤 4 中的图像 1,2 Game Boy Advance Back Shell Replacement, Remove the back shell screws: 步骤 4 中的图像 2,2
      • Remove the seven screws securing the back shell:
      • Six 9.4 mm‑long tri‑point Y0 screws
      • One 8.5 mm‑long JIS 1 screw
      • You can try to use a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping screws. Push down firmly on the driver and twist slowly.
      询问修复机器人
      添加评论
    2. Game Boy Advance Back Shell Replacement, Remove the back shell: 步骤 5 中的图像 1,2 Game Boy Advance Back Shell Replacement, Remove the back shell: 步骤 5 中的图像 2,2
      • Lift the back shell straight up and remove it.
      • During reassembly, squeeze the shell firmly around the edges and ensure the shoulder buttons and bumpers are properly seated with no large gaps. Gently test the buttons to make sure everything feels correct.
      询问修复机器人
      添加评论
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for troubleshooting help.
取消:我没有完成这个指南。
5等其他人完成本指南。
Spencer Day
于09/14/22注册
208,338 声望
创作了1,266篇指南
2指南评论
Seeing the GBA-SP guide, could information here be added so we know which mm triwing screws the regular GBA backpanel uses?
rguich - 回复 分享
We've updated the guide, and it now includes the screw measurements.
Spencer Day - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 49
过去 30 天: 174
总计 14,203
