Galaxy Book3 360 13" SSD Replacement
简介
转到步骤 1To replace the SSD you will need a Pry Tool and Phillips screw driver.
你所需要的
Flip the laptop over and remove each rubber shoe
Use a Philips screwdriver to care fully remove each screw
After removing the screws carefully pry open the case starting on the top right hinge.
There is a clip in the center of the laptop , when the edges are completely removed lift carefully to unclip the center.
Carefully remove the screw holding down the SSD.
Lift the SSD until it is at about a 10-degree angle and then slide it out of the socket.
Slide in your new SSD, and follow the previous steps in reverse.
5等其他人完成本指南。
5指南评论
Are you sure for the second slot it is 2280 and not 2230?
How can I be sure for my NP750QFG that it's 2280 and not 2230?
Any advice?
Galaxy book 3 360 15.6" inch variant support Gen 3 NVMe 2280 type ssd like WD Black SN770
Mine is 15.6 size and it's for the second slot, the 13" I think didn't have a second slot.
How do I know i it's for 2230 or 2280?
I opened my Book3 Pro 360 5G and the SSD is covered by a metal shield. How do I remove this shield to gain access to the SSD and slot?
