跳转到主内容
Fujifilm FinePix F505EXR Selector Button Circuit Board Replacement
你所需要的
  1. Fujifilm FinePix F505EXR Selector Button Circuit Board Replacement, Battery: 步骤 1 中的图像 1,2 Fujifilm FinePix F505EXR Selector Button Circuit Board Replacement, Battery: 步骤 1 中的图像 2,2
    • Power the device down before taking any other actions.
    • Hold the camera with the lens facing towards youself.
    • Turn the camera upside down and place your right thumb on the battery chamber cover.
  2. Fujifilm FinePix F505EXR Selector Button Circuit Board Replacement: 步骤 2 中的图像 1,2 Fujifilm FinePix F505EXR Selector Button Circuit Board Replacement: 步骤 2 中的图像 2,2
    • Hold the camera, then pull the battery chamber towards yourself with your right thumb.
    • Pull the cover entirely out and release it to reveal the battery.
  3. Fujifilm FinePix F505EXR Selector Button Circuit Board Replacement: 步骤 3 中的图像 1,2 Fujifilm FinePix F505EXR Selector Button Circuit Board Replacement: 步骤 3 中的图像 2,2
    • Locate the orange battery latch that holds the battery in place.
    • Use your finger to push the latch away from yourself to release the battery.
    • Remove the battery manually from the battery chamber.
    • Place the battery into a charger if it is dead.
    • Remove battery before performing any other repairs.
    • Replace defective battery if previous steps fail
    • Contact support on the Fujifilm website for further assistance
  4. Fujifilm FinePix F505EXR Selector Button Circuit Board Replacement, Selector Button Circuit Board: 步骤 5 中的图像 1,3 Fujifilm FinePix F505EXR Selector Button Circuit Board Replacement, Selector Button Circuit Board: 步骤 5 中的图像 2,3 Fujifilm FinePix F505EXR Selector Button Circuit Board Replacement, Selector Button Circuit Board: 步骤 5 中的图像 3,3
    • Remove four 2.5mm Phillips #1 screws on the bottom of the camera near where the camera mount attaches.
    • Remove two 5.1mm Phillips #1 screws on the left side of the camera relative to the LCD screen.
    • Remove two 5.1mm Phillips #1 screws on the right side of the camera relative to the LCD screen nearest to the mode wheel.
  5. Fujifilm FinePix F505EXR Selector Button Circuit Board Replacement: 步骤 6 中的图像 1,2 Fujifilm FinePix F505EXR Selector Button Circuit Board Replacement: 步骤 6 中的图像 2,2
    • Place the camera lens face down with the LCD screen face up on a flat surface, or hold it. Carefully lift the camera’s back cover approximately 1 inch.
    • Carefully lift the ribbon clamp connector back using the tweezers and remove the blue ribbon.
    • Do NOT pull on ribbon if the ribbon clamp connector still grasps the blue ribbon. This could cause severe damage to the ribbon.
    • If you are replacing the LCD monitor you can skip steps 6 and 7 for the selector button circuit board guide and go directly to the LCD monitor repair guide.
    • If you are replacing the Mode Dial you can skip steps 6 and 7 for the selector button circuit board guide and go directly to the Mode Dial repair guide.
  6. Fujifilm FinePix F505EXR Selector Button Circuit Board Replacement: 步骤 7 中的图像 1,1
    • Remove the back of the camera case and place it on a flat surface with the selector button circuit board facing up.
    • Remove the three 3.5mm Phillips #1 screws located on the chip seen in the image.
  7. Fujifilm FinePix F505EXR Selector Button Circuit Board Replacement: 步骤 8 中的图像 1,3 Fujifilm FinePix F505EXR Selector Button Circuit Board Replacement: 步骤 8 中的图像 2,3 Fujifilm FinePix F505EXR Selector Button Circuit Board Replacement: 步骤 8 中的图像 3,3
    • Lift the chip with tweezers to remove it from the other remaining components.
结论
另外一个人完成了本指南。
Matthew Kilmonis
于03/08/17注册
219 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 219
