跳转到主内容
Framework Laptop 16" Webcam Module Replacement
你所需要的
  1. Framework Laptop 16" Webcam Module Replacement, Before you begin: 步骤 1 中的图像 1,2 Framework Laptop 16" Webcam Module Replacement, Before you begin: 步骤 1 中的图像 2,2
    • Unplug all cables and fully shut down your laptop.
    • If your repair requires a spudger, a T5 Torx, or a Phillips screwdriver, you can use the included Framework screwdriver. Whichever works best for you!
  2. Framework Laptop 16" Webcam Module Replacement, Create a gap: 步骤 2 中的图像 1,3 Framework Laptop 16" Webcam Module Replacement, Create a gap: 步骤 2 中的图像 2,3 Framework Laptop 16" Webcam Module Replacement, Create a gap: 步骤 2 中的图像 3,3
    • The bezel is secured with magnets!
    • Slide your fingernail under the inside edge of either bottom corner of the bezel.
    • Pull the bezel away from the screen to release the first few magnets.
  3. Framework Laptop 16" Webcam Module Replacement, Remove the bezel: 步骤 3 中的图像 1,3 Framework Laptop 16" Webcam Module Replacement, Remove the bezel: 步骤 3 中的图像 2,3 Framework Laptop 16" Webcam Module Replacement, Remove the bezel: 步骤 3 中的图像 3,3
    • Lift the bezel around the perimeter of the screen until all of its magnets are released.
    • Remove the bezel.
  4. Framework Laptop 16" Webcam Module Replacement, Disconnect the webcam module: 步骤 4 中的图像 1,2 Framework Laptop 16" Webcam Module Replacement, Disconnect the webcam module: 步骤 4 中的图像 2,2
    • Use the flat end of a spudger, or a clean fingernail, to lift up the locking tab on the webcam module ZIF connector.
  5. Framework Laptop 16" Webcam Module Replacement, Remove the webcam module screws: 步骤 5 中的图像 1,3 Framework Laptop 16" Webcam Module Replacement, Remove the webcam module screws: 步骤 5 中的图像 2,3 Framework Laptop 16" Webcam Module Replacement, Remove the webcam module screws: 步骤 5 中的图像 3,3
    • Use a T5 Torx screwdriver to remove the two 2 mm‑long screws securing the webcam module.
    • The screws thread through metal brackets. If they come off with the screws, you can skip the next step.
    • During reassembly, support the screen frame with your other hand as you reinsert screws to prevent the laptop from accidentally tipping over.
  6. Framework Laptop 16" Webcam Module Replacement: 步骤 6 中的图像 1,3 Framework Laptop 16" Webcam Module Replacement: 步骤 6 中的图像 2,3 Framework Laptop 16" Webcam Module Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    • Use tweezers, or your fingers, to remove the two metal brackets on both ends of the webcam module.
  7. Framework Laptop 16" Webcam Module Replacement, Remove the webcam module: 步骤 7 中的图像 1,3 Framework Laptop 16" Webcam Module Replacement, Remove the webcam module: 步骤 7 中的图像 2,3 Framework Laptop 16" Webcam Module Replacement, Remove the webcam module: 步骤 7 中的图像 3,3
    • Use tweezers to lift the right side of the webcam module until the cable slides out of the ZIF connector.
    • Remove the webcam module.
  8. Framework Laptop 16" Webcam Module Replacement, Reassembly information: 步骤 8 中的图像 1,3 Framework Laptop 16" Webcam Module Replacement, Reassembly information: 步骤 8 中的图像 2,3 Framework Laptop 16" Webcam Module Replacement, Reassembly information: 步骤 8 中的图像 3,3
    • Reconnecting the webcam module is a little tricky. If you're having difficulty, you can reposition the display to give the webcam cable more slack.
    • During reassembly, follow these instructions to reinstall a new webcam module:
    • Use tweezers to gently bend the webcam cable away from the screen frame.
    • Use your other hand to align the webcam module over the cable and lower it into place.
    • Make sure the webcam module sits level with the display before flipping down the cable locking tab and continuing reassembly.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Alex Diaz-Kokaisl
于01/16/22注册
214,548 声望
创作了1,044篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,764篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 25
总计 663
