跳转到主内容
加入维修社区 - 创建账户
Framework Laptop 16" Display Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Framework Laptop 16" Display Replacement, Before you begin: 步骤 1 中的图像 1,2 Framework Laptop 16" Display Replacement, Before you begin: 步骤 1 中的图像 2,2
    • Unplug all cables and fully shut down your laptop.
    • If your repair requires a spudger, a T5 Torx, or a Phillips screwdriver, you can use the included Framework screwdriver. Whichever works best for you!
  2. Framework Laptop 16" Display Replacement, Create a gap: 步骤 2 中的图像 1,3 Framework Laptop 16" Display Replacement, Create a gap: 步骤 2 中的图像 2,3 Framework Laptop 16" Display Replacement, Create a gap: 步骤 2 中的图像 3,3
    • The bezel is secured with magnets!
    • Slide your fingernail under the inside edge of either bottom corner of the bezel.
    • Pull the bezel away from the screen to release the first few magnets.
  3. Framework Laptop 16" Display Replacement, Remove the bezel: 步骤 3 中的图像 1,3 Framework Laptop 16" Display Replacement, Remove the bezel: 步骤 3 中的图像 2,3 Framework Laptop 16" Display Replacement, Remove the bezel: 步骤 3 中的图像 3,3
    • Lift the bezel around the perimeter of the screen until all of its magnets are released.
    • Remove the bezel.
  4. Framework Laptop 16" Display Replacement, Remove the display screws: 步骤 4 中的图像 1,3 Framework Laptop 16" Display Replacement, Remove the display screws: 步骤 4 中的图像 2,3 Framework Laptop 16" Display Replacement, Remove the display screws: 步骤 4 中的图像 3,3
    • Use a T5 Torx screwdriver to remove the four 2.4 mm‑long screws securing the display.
    • During reassembly, support the screen frame with your other hand as you reinsert screws to prevent the laptop from accidentally tipping over.
  5. Framework Laptop 16" Display Replacement, Disconnect the display: 步骤 5 中的图像 1,3 Framework Laptop 16" Display Replacement, Disconnect the display: 步骤 5 中的图像 2,3 Framework Laptop 16" Display Replacement, Disconnect the display: 步骤 5 中的图像 3,3
    • Grab the display and pull it straight off the screen frame to free it from its alignment pegs.
    • Don't pull the display too far from the frame, as it's still attached by a cable.
    • Flip the front of the display down and rest it on the keyboard.
  6. Framework Laptop 16" Display Replacement: 步骤 6 中的图像 1,2 Framework Laptop 16" Display Replacement: 步骤 6 中的图像 2,2
    • Use your fingers to flip up the plastic tab and access the connector underneath.
  7. Framework Laptop 16" Display Replacement: 步骤 7 中的图像 1,2 Framework Laptop 16" Display Replacement: 步骤 7 中的图像 2,2
    • Use the flat end of a spudger to lift up the metal locking tab over the display connector.
  8. Framework Laptop 16" Display Replacement, Remove the display: 步骤 8 中的图像 1,3 Framework Laptop 16" Display Replacement, Remove the display: 步骤 8 中的图像 2,3 Framework Laptop 16" Display Replacement, Remove the display: 步骤 8 中的图像 3,3
    • Grip the display cable where it meets the connector head.
    • Slide the connector straight out of its socket to disconnect it.
    • Remove the display.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
2等其他人完成本指南。
Alex Diaz-Kokaisl
于01/16/22注册
217,647 声望
创作了1,087篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,966篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 70
总计 1,295
