跳转到主内容
加入维修社区 - 创建账户
Framework Laptop 12 Touchpad Replacement
你所需要的
  1. Framework Laptop 12 Touchpad Replacement, Power down your laptop: 步骤 1 中的图像 1,3 Framework Laptop 12 Touchpad Replacement, Power down your laptop: 步骤 1 中的图像 2,3 Framework Laptop 12 Touchpad Replacement, Power down your laptop: 步骤 1 中的图像 3,3
    • Before you begin repairs, unplug your laptop and shut it down from the operating system. This ensures that the laptop isn't in standby/suspend mode.
    • The indicator LEDs along the edges should be unlit. The laptop should be silent.
    • If you accidentally turn on the laptop during repair, hold the power button down for 10 seconds to shut it down.
    • Make sure your Framework Screwdriver has the T5 Torx bit (labeled as T-5) facing outwards. If it's not, pull the bit out and flip it.
  2. Framework Laptop 12 Touchpad Replacement, Set your laptop down: 步骤 2 中的图像 1,1
    • Set your Framework Laptop face-down on a clean work surface.
  3. Framework Laptop 12 Touchpad Replacement, Loosen the bottom screws: 步骤 3 中的图像 1,2 Framework Laptop 12 Touchpad Replacement, Loosen the bottom screws: 步骤 3 中的图像 2,2
    • Use your Framework Screwdriver to fully loosen the eight captive T5 Torx screws on the bottom of your laptop.
    • Most screws in your Framework Laptop (including these) are captive—they're designed to stay in place after you loosen them.
  4. Framework Laptop 12 Touchpad Replacement, Flip your laptop over: 步骤 4 中的图像 1,1
    • Flip your laptop over so it's face-up on your work surface.
  5. Framework Laptop 12 Touchpad Replacement, Open your laptop: 步骤 5 中的图像 1,2 Framework Laptop 12 Touchpad Replacement, Open your laptop: 步骤 5 中的图像 2,2
    • Open the laptop lid so that both the screen and the base lie flat on your work surface.
  6. Framework Laptop 12 Touchpad Replacement, Remove the Input Cover: 步骤 6 中的图像 1,3 Framework Laptop 12 Touchpad Replacement, Remove the Input Cover: 步骤 6 中的图像 2,3 Framework Laptop 12 Touchpad Replacement, Remove the Input Cover: 步骤 6 中的图像 3,3
    • Use your fingers to grip the Input Cover in the hinge cutouts.
    • Lift upwards to swing the Input Cover up from the base of the laptop.
    • Magnets hold the Input Cover down, so you'll feel some resistance. If it feels stuck, check that you've fully loosened all the screws on the bottom of your laptop.
    • Remove the Input Cover.
  7. Framework Laptop 12 Touchpad Replacement, Disconnect the touchpad: 步骤 7 中的图像 1,3 Framework Laptop 12 Touchpad Replacement, Disconnect the touchpad: 步骤 7 中的图像 2,3 Framework Laptop 12 Touchpad Replacement, Disconnect the touchpad: 步骤 7 中的图像 3,3
    • Use the flat end of your Framework Screwdriver or a fingernail to gently pry up the black locking tab on the touchpad cable ZIF connector, located on the back of the touchpad.
  8. Framework Laptop 12 Touchpad Replacement: 步骤 8 中的图像 1,2 Framework Laptop 12 Touchpad Replacement: 步骤 8 中的图像 2,2
    • Grab the touchpad cable by the brown tab and slide it out of its connector.
  9. Framework Laptop 12 Touchpad Replacement: 步骤 9 中的图像 1,3 Framework Laptop 12 Touchpad Replacement: 步骤 9 中的图像 2,3 Framework Laptop 12 Touchpad Replacement: 步骤 9 中的图像 3,3
    • Use the flat end of your Framework Screwdriver or a fingernail to gently pry up the black locking tab on the keyboard cable ZIF connector, located on the back of the touchpad.
  10. Framework Laptop 12 Touchpad Replacement: 步骤 10 中的图像 1,2 Framework Laptop 12 Touchpad Replacement: 步骤 10 中的图像 2,2
    • Grab the keyboard cable by the blue tab and slide it out of its connector.
  11. Framework Laptop 12 Touchpad Replacement, Remove the touchpad screws: 步骤 11 中的图像 1,2 Framework Laptop 12 Touchpad Replacement, Remove the touchpad screws: 步骤 11 中的图像 2,2
    • Use your Framework Screwdriver to remove the seven 2.1 mm‑long T5 Torx screws securing the touchpad.
    • If your replacement touchpad comes with screws, you don't need to keep these for reassembly.
  12. Framework Laptop 12 Touchpad Replacement, Remove the touchpad: 步骤 12 中的图像 1,3 Framework Laptop 12 Touchpad Replacement, Remove the touchpad: 步骤 12 中的图像 2,3 Framework Laptop 12 Touchpad Replacement, Remove the touchpad: 步骤 12 中的图像 3,3
    • Use your fingers to pop the touchpad out of the Input Cover from the underside.
    • Lift and remove the touchpad.
  13. Framework Laptop 12 Touchpad Replacement, Disassembly complete: 步骤 13 中的图像 1,1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
  14. Framework Laptop 12 Touchpad Replacement, Align the replacement touchpad: 步骤 14 中的图像 1,1
    • The replacement touchpad comes with a blue plastic alignment tool pre-installed. Don't remove this from the touchpad yet.
    • Make sure the small tabs around the alignment tool are folded down around the touchpad. Use your fingers to fold them down if they're not.
  15. Framework Laptop 12 Touchpad Replacement: 步骤 15 中的图像 1,2 Framework Laptop 12 Touchpad Replacement: 步骤 15 中的图像 2,2
    • Lay the touchpad into its Input Cover recess.
    • The tabs on the alignment tool will center the touchpad on the Input Cover.
  16. Framework Laptop 12 Touchpad Replacement, Install the touchpad screws: 步骤 16 中的图像 1,2 Framework Laptop 12 Touchpad Replacement, Install the touchpad screws: 步骤 16 中的图像 2,2
    • Use your Framework Screwdriver to install the seven 2.1 mm‑long T5 Torx screws to secure the touchpad.
    • If you didn't use an alignment tool, manually center the touchpad to the Input Cover before tightening the screws.
    • Tighten the screws until they're snug. Don't over-tighten them, or you may strip the screws.
  17. Framework Laptop 12 Touchpad Replacement, Connect the touchpad cables: 步骤 17 中的图像 1,3 Framework Laptop 12 Touchpad Replacement, Connect the touchpad cables: 步骤 17 中的图像 2,3 Framework Laptop 12 Touchpad Replacement, Connect the touchpad cables: 步骤 17 中的图像 3,3
    • Slide the keyboard ZIF cable into its connector, up to the printed line on the cable.
    • Use your finger to flip down and gently press the locking tab in place.
  18. Framework Laptop 12 Touchpad Replacement: 步骤 18 中的图像 1,3 Framework Laptop 12 Touchpad Replacement: 步骤 18 中的图像 2,3 Framework Laptop 12 Touchpad Replacement: 步骤 18 中的图像 3,3
    • Slide the touchpad ZIF cable into its connector, up to the printed line on the cable.
  19. Framework Laptop 12 Touchpad Replacement, Remove the alignment tool: 步骤 19 中的图像 1,2 Framework Laptop 12 Touchpad Replacement, Remove the alignment tool: 步骤 19 中的图像 2,2
    • Skip this step if you didn't use an alignment tool.
    • Use your fingers to peel and remove the alignment tool from the touchpad.
  20. Framework Laptop 12 Touchpad Replacement, Install the Input Cover: 步骤 20 中的图像 1,3 Framework Laptop 12 Touchpad Replacement, Install the Input Cover: 步骤 20 中的图像 2,3 Framework Laptop 12 Touchpad Replacement, Install the Input Cover: 步骤 20 中的图像 3,3
    • Angle the bottom edge of the Input Cover towards the base of the laptop.
    • Align and insert the bottom edge of the Input Cover into the base of the laptop.
    • Make sure the slots along the bottom edge of the Input Cover slide into the tabs in the base.
    • Lower the Input Cover's top edge onto the laptop until the magnets snap it in place.
    • Make sure the Input Cover sits neatly within the laptop frame and no corners are popping up.
  21. Framework Laptop 12 Touchpad Replacement, Close and flip your laptop: 步骤 21 中的图像 1,2 Framework Laptop 12 Touchpad Replacement, Close and flip your laptop: 步骤 21 中的图像 2,2
    • Close the laptop lid.
    • Flip your laptop face-down on a clean work surface.
  22. Framework Laptop 12 Touchpad Replacement, Tighten the bottom screws: 步骤 22 中的图像 1,2 Framework Laptop 12 Touchpad Replacement, Tighten the bottom screws: 步骤 22 中的图像 2,2
    • Use your Framework Screwdriver to tighten the eight captive T5 Torx screws on the bottom of your laptop.
结论
You finished fixing your Framework Laptop!
If you need help, contact Framework support.
Arthur Shi
于01/03/18注册
316,625 声望
创作了730篇指南
团队
Guide Team Guide Team 的会员
Staff
10 名成员
创作了16,123篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 14
过去 30 天: 44
总计 604
