跳转到主内容
加入维修社区 - 创建账户
Framework Laptop 12 Display Removal
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Framework Laptop 12 Display Removal, Power down your laptop: 步骤 1 中的图像 1,3 Framework Laptop 12 Display Removal, Power down your laptop: 步骤 1 中的图像 2,3 Framework Laptop 12 Display Removal, Power down your laptop: 步骤 1 中的图像 3,3
    • Before you begin repairs, unplug your laptop and shut it down from the operating system. This ensures that the laptop isn't in standby/suspend mode.
    • The indicator LEDs along the edges should be unlit. The laptop should be silent.
    • If you accidentally turn on the laptop during repair, hold the power button down for 10 seconds to shut it down.
    • Make sure your Framework Screwdriver has the T5 Torx bit (labeled as T-5) facing outwards. If it's not, pull the bit out and flip it.
  2. Framework Laptop 12 Display Removal, Open your laptop: 步骤 2 中的图像 1,2 Framework Laptop 12 Display Removal, Open your laptop: 步骤 2 中的图像 2,2
    • Open the laptop lid so that both the screen and the base lie flat on your work surface.
  3. Framework Laptop 12 Display Removal, Remove the Display Cover: 步骤 3 中的图像 1,2 Framework Laptop 12 Display Removal, Remove the Display Cover: 步骤 3 中的图像 2,2
    • The Display Cover is held in place with magnets along the top edge and clips along the remaining edges.
    • Use the flat end of your Framework Screwdriver to pry up the right edge of the Display Cover.
  4. Framework Laptop 12 Display Removal: 步骤 4 中的图像 1,3 Framework Laptop 12 Display Removal: 步骤 4 中的图像 2,3 Framework Laptop 12 Display Removal: 步骤 4 中的图像 3,3
    • Slide your fingers under the top edge of the Display Cover to release it from the laptop.
  5. Framework Laptop 12 Display Removal: 步骤 5 中的图像 1,2 Framework Laptop 12 Display Removal: 步骤 5 中的图像 2,2
    • Remove the Display Cover.
  6. Framework Laptop 12 Display Removal, Remove the display screws: 步骤 6 中的图像 1,2 Framework Laptop 12 Display Removal, Remove the display screws: 步骤 6 中的图像 2,2
    • Use your Framework Screwdriver to remove the four 3.3 mm‑long T5 Torx screws securing the display to the Top Cover.
    • These screws are not captive. Store them in a safe location for reassembly.
  7. Framework Laptop 12 Display Removal, Slide the display down: 步骤 7 中的图像 1,3 Framework Laptop 12 Display Removal, Slide the display down: 步骤 7 中的图像 2,3 Framework Laptop 12 Display Removal, Slide the display down: 步骤 7 中的图像 3,3
    • Insert the bit end of your Framework Screwdriver into the small hole on the display, below the Framework logo.
    • Slide the display down towards the hinge edge to release the tabs holding the top edge of the display in place.
  8. Framework Laptop 12 Display Removal, Lift the display: 步骤 8 中的图像 1,2 Framework Laptop 12 Display Removal, Lift the display: 步骤 8 中的图像 2,2
    • Use your fingers to lift the top edge of the display from the Top Cover.
  9. Framework Laptop 12 Display Removal, Swing the display over: 步骤 9 中的图像 1,3 Framework Laptop 12 Display Removal, Swing the display over: 步骤 9 中的图像 2,3 Framework Laptop 12 Display Removal, Swing the display over: 步骤 9 中的图像 3,3
    • Use your fingers to carefully swing the display over so it lies on top of the keyboard.
  10. Framework Laptop 12 Display Removal, Remove the webcam bracket: 步骤 10 中的图像 1,1
    • Use your Framework Screwdriver to remove the two 3.3 mm‑long T5 Torx screws securing the webcam bracket on the top edge behind the display.
  11. Framework Laptop 12 Display Removal: 步骤 11 中的图像 1,2 Framework Laptop 12 Display Removal: 步骤 11 中的图像 2,2
    • Lift and remove the webcam bracket.
  12. Framework Laptop 12 Display Removal, Disconnect the webcam: 步骤 12 中的图像 1,3 Framework Laptop 12 Display Removal, Disconnect the webcam: 步骤 12 中的图像 2,3 Framework Laptop 12 Display Removal, Disconnect the webcam: 步骤 12 中的图像 3,3
    • Use the flat end of your Framework Screwdriver to lift the webcam out of its recess.
    • Avoid touching the black camera module near the center of the webcam.
    • Flip the webcam over and gently hold it down with your fingers.
  13. Framework Laptop 12 Display Removal: 步骤 13 中的图像 1,3 Framework Laptop 12 Display Removal: 步骤 13 中的图像 2,3 Framework Laptop 12 Display Removal: 步骤 13 中的图像 3,3
    • Use the flat end of your Framework Screwdriver or a fingernail to gently pry up the locking tab on the webcam cable ZIF connector.
  14. Framework Laptop 12 Display Removal, Remove the webcam: 步骤 14 中的图像 1,3 Framework Laptop 12 Display Removal, Remove the webcam: 步骤 14 中的图像 2,3 Framework Laptop 12 Display Removal, Remove the webcam: 步骤 14 中的图像 3,3
    • Slide the webcam cable out of its connector.
    • Remove the webcam.
  15. Framework Laptop 12 Display Removal, Detach the webcam cable: 步骤 15 中的图像 1,3 Framework Laptop 12 Display Removal, Detach the webcam cable: 步骤 15 中的图像 2,3 Framework Laptop 12 Display Removal, Detach the webcam cable: 步骤 15 中的图像 3,3
    • The webcam cable is lightly adhered to the display.
    • Grab the webcam cable with your fingers and slowly peel it away from the display.
    • Carefully move the cable off of the display.
  16. Framework Laptop 12 Display Removal, Disconnect the touch control cable: 步骤 16 中的图像 1,3 Framework Laptop 12 Display Removal, Disconnect the touch control cable: 步骤 16 中的图像 2,3 Framework Laptop 12 Display Removal, Disconnect the touch control cable: 步骤 16 中的图像 3,3
    • Use the flat end of your Framework Screwdriver or a fingernail to gently pry up the locking tab on the touch control ZIF connector near the hinge edge of the display.
    • Use your fingers to grab the touch control cable by the blue tab and slide the cable out of the connector.
  17. Framework Laptop 12 Display Removal, Separate the silver tape: 步骤 17 中的图像 1,3 Framework Laptop 12 Display Removal, Separate the silver tape: 步骤 17 中的图像 2,3 Framework Laptop 12 Display Removal, Separate the silver tape: 步骤 17 中的图像 3,3
    • Slide the flat end of your Framework Screwdriver under the grounding tape securing the display cable.
    • Lift slowly to separate the tape from the display.
    • Keep this tape clean and intact during your repair. You'll use it to attach the cable during reassembly.
  18. Framework Laptop 12 Display Removal, Detach the display cable: 步骤 18 中的图像 1,3 Framework Laptop 12 Display Removal, Detach the display cable: 步骤 18 中的图像 2,3 Framework Laptop 12 Display Removal, Detach the display cable: 步骤 18 中的图像 3,3
    • The display cable is lightly adhered to the bottom edge of the display.
    • Slide the flat end of your Framework Screwdriver under the length of the display cable to separate it from the display.
  19. Framework Laptop 12 Display Removal, Disconnect the display cable: 步骤 19 中的图像 1,2 Framework Laptop 12 Display Removal, Disconnect the display cable: 步骤 19 中的图像 2,2
    • Use your fingers to peel up the clear tab covering the display cable connector.
  20. Framework Laptop 12 Display Removal: 步骤 20 中的图像 1,2 Framework Laptop 12 Display Removal: 步骤 20 中的图像 2,2
    • Use the flat end of your Framework Screwdriver to flip up the locking bar around the display connector.
  21. Framework Laptop 12 Display Removal: 步骤 21 中的图像 1,2 Framework Laptop 12 Display Removal: 步骤 21 中的图像 2,2
    • Make sure the locking bar doesn't fall back in place while you disconnect the display cable.
    • Grasp the display cable near the connector and slide it out of the connector.
    • If you have trouble getting the cable to slide out, gently wiggle it to loosen the connection.
  22. Framework Laptop 12 Display Removal, Remove the display: 步骤 22 中的图像 1,3 Framework Laptop 12 Display Removal, Remove the display: 步骤 22 中的图像 2,3 Framework Laptop 12 Display Removal, Remove the display: 步骤 22 中的图像 3,3
    • Carefully lift and remove the display.
终点
Arthur Shi
于01/03/18注册
316,808 声望
创作了730篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 43
