跳转到主内容
加入维修社区 - 创建账户
Flipper Zero Display Replacement
你所需要的
    • Go to Main Menu > Settings > Power.
    • Select Power OFF.
    • Alternatively, you can press and hold the Back-button for around 10 seconds.
    • Confirm by pressing the Right-button.
    询问修复机器人
    添加评论
  1. Flipper Zero Display Replacement, Remove the microSD card: 步骤 2 中的图像 1,1
    • Eject the microSD card by pressing it with your fingernail.
    添加评论
  2. Flipper Zero Display Replacement, Remove the screws: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    Phillips #0 Screwdriver
    $5.49
    • Use a PH0 screwdriver to unscrew the four long screws holding the back cover.
    • Be careful, the screws are quite easy to strip.
    添加评论
  3. Flipper Zero Display Replacement, Open the back cover: 步骤 4 中的图像 1,3 Flipper Zero Display Replacement, Open the back cover: 步骤 4 中的图像 2,3 Flipper Zero Display Replacement, Open the back cover: 步骤 4 中的图像 3,3
    • Press the middle of the top cover on both sides, one by one, to release the latches that hold the back cover in place.
    • Once the latches are released, you can remove the bottom cover.
    询问修复机器人
    添加评论
  4. Flipper Zero Display Replacement, Seperate the chassis from the top cover: 步骤 5 中的图像 1,2 Flipper Zero Display Replacement, Seperate the chassis from the top cover: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    $5.49
    • Use a PH0 screwdriver to unscrew the two short screws that are holding the chassis and top cover together.
    • Once the screws are removed, separate the chassis from the top cover.
    添加评论
  5. Flipper Zero Display Replacement, Disconnect the battery: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    Spudger
    $3.99
    • Disconnect the battery by carefully prying the connector with a Spudger and pulling it out.
    询问修复机器人
    添加评论
  6. Flipper Zero Display Replacement, Disconnect the ribbon cable: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    iFixit Opening Picks (Set of 6)
    $4.95
    • Disconnect the large ribbon cable from the board. Use a plastic pick to lift the latch up to open the lock and carefully pull it out of the connector.
    询问修复机器人
    添加评论
  7. Flipper Zero Display Replacement, Release the battery chassis: 步骤 8 中的图像 1,2 Flipper Zero Display Replacement, Release the battery chassis: 步骤 8 中的图像 2,2
    • To release the battery chassis, lightly rock it back and forth while pulling the two parts apart.
    • Be sure to apply gentle and consistent pressure to avoid damaging the device.
    询问修复机器人
    添加评论
  8. Flipper Zero Display Replacement, Unscrew the the button chassis: 步骤 9 中的图像 1,1
    在这个步骤中使用的工具:
    $5.49
    • Unscrew the two short screws holding the button chassis using a PH0 screwdriver.
    询问修复机器人
    添加评论
  9. Flipper Zero Display Replacement, Seperate the button chassis: 步骤 10 中的图像 1,3 Flipper Zero Display Replacement, Seperate the button chassis: 步骤 10 中的图像 2,3 Flipper Zero Display Replacement, Seperate the button chassis: 步骤 10 中的图像 3,3
    • To seperate the button chassis and the board, press the latch on the side shown below and pull the chassis away from the board.
    询问修复机器人
    添加评论
  10. Flipper Zero Display Replacement, Disconnect the screen: 步骤 11 中的图像 1,2 Flipper Zero Display Replacement, Disconnect the screen: 步骤 11 中的图像 2,2
    在这个步骤中使用的工具:
    $4.95
    • Disconnect the screen ribbon cable from the board. Use a plastic pick to lift the latch up to open the lock and carefully pull it out of the connector.
    添加评论
  11. Flipper Zero Display Replacement, Desolder the screen: 步骤 12 中的图像 1,1
    • To remove the screen you need to desolder two contacts.
    • See this guide on how to solder and desolder connections.
    添加评论
结论
取消:我没有完成这个指南。
16等其他人完成本指南。
Sebastian
于08/19/18注册
33,352 声望
创作了72篇指南
14指南评论
Everything worked fine following this guide. Thank you for the help. In my case was just the glass that was broken, so at the end, i didnt needed to desolder. Just removed the glass with the Plastic pick and worked perfectly. Thank you again for the help.
arthureldo - 回复 分享
Where did you find a replacement glass?
Ben Durrant - 回复 分享
The company behind FZ is not selling screen replacement (they promise they will do it in the future) but for now... So i don't what to think about this guide
Gusbill - 回复 分享
Where can you get an LCD replacement (backlit)?
David Williams - 回复 分享
Checked with Flipper Zero Support and they said there's no replacement screens available. Found one on AliExpress and ordered it so I'll post here in about a month once the display has arrived and I have time to try the replacement, then report back and link the part if successful.
Cody Ouellette - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 79
过去 30 天: 382
总计 26,981
