跳转到主内容
加入维修社区 - 创建账户
First Act MA2039 Damaged Wire Replacement
你所需要的
    1. First Act MA2039 Damaged Wire Replacement, First Act MA2039 Damaged Wire Replacement: 步骤 1 中的图像 1,2 First Act MA2039 Damaged Wire Replacement, First Act MA2039 Damaged Wire Replacement: 步骤 1 中的图像 2,2
      • Place the speaker with its front side facing down.
      • Use a Phillips #0 screwdriver to remove the two 25 mm screws from the left and right sides of the battery cartridges.
      • Open both lids to the battery cartridges.
      询问修复机器人
      添加评论
    2. First Act MA2039 Damaged Wire Replacement: 步骤 2 中的图像 1,3 First Act MA2039 Damaged Wire Replacement: 步骤 2 中的图像 2,3 First Act MA2039 Damaged Wire Replacement: 步骤 2 中的图像 3,3
      • As you begin to lift the back panel off the amplifier, push the battery terminals through the open slots of the battery cartridges.
      • Use your fingers to prop the back panel and lift it away from the amplifier.
      • Lift the back panel off completely and set it to the side.
      询问修复机器人
      添加评论
    3. First Act MA2039 Damaged Wire Replacement: 步骤 3 中的图像 1,3 First Act MA2039 Damaged Wire Replacement: 步骤 3 中的图像 2,3 First Act MA2039 Damaged Wire Replacement: 步骤 3 中的图像 3,3
      • With the back panel off, this will help make space for the silver compartment to be removed.
      • Unscrew four 25 mm screws with a Phillips #0 screwdriver from the top of the amplifier.
      • Press firmly on the input jack and tone adjustment knob of the silver compartment to free it from its resting position.
      询问修复机器人
      添加评论
    4. First Act MA2039 Damaged Wire Replacement: 步骤 4 中的图像 1,3 First Act MA2039 Damaged Wire Replacement: 步骤 4 中的图像 2,3 First Act MA2039 Damaged Wire Replacement: 步骤 4 中的图像 3,3
      • Rotate the silver compartment so that you have a clear visual of the motherboard and its components.
      • For effective work on the wiring, lodge the compartment on top of the back portion of the amplifier.
      • Check the wiring components for blown fuses or damaged connections.
      询问修复机器人
      添加评论
    5. First Act MA2039 Damaged Wire Replacement: 步骤 5 中的图像 1,1
      • Lift the silver compartment to see where the wires are further connected.
      • Make sure that the terminals from the circuit to the amplifier are connected securely.
      • Check to see if there is loose wiring from the motherboard.
      • If there is damaged wire to the amplifier or motherboard in the silver compartment, refer this Soldering guide to replace wires and fix connections.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 24
总计 705
