跳转到主内容
Fender Jazz Bass Strings Replacement
Matthew Caldera
Matthew Caldera3 其他贡献者
最后更新于 November 13, 2022
10 - 15 分钟
简单
String replacement of a Fender Jazz Bass is a common replacement on the bass that can be dependent on how often you play and the type of stress you are putting on your strings. Learning the basics of string replacement will allow you to tune your bass more to your personalized liking and to fear not if a string is to break.
String replacement can be a very basic task, however, it is always an option to elevate your string replacement task with tools that might make it easier. These instructions give you a idea of the essential tasks that are required to have fresh sounding strings in no time.
你所需要的
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. Fender Jazz Bass Strings Replacement, Strings: 步骤 1 中的图像 1,1
    • Loosen the strings by turning the tuning pegs.
  2. Fender Jazz Bass Strings Replacement: 步骤 2 中的图像 1,1
    • Once the strings are loose, remove them from the tuning pegs.
    • If you prefer, you can also cut the strings off.
  3. Fender Jazz Bass Strings Replacement: 步骤 3 中的图像 1,2 Fender Jazz Bass Strings Replacement: 步骤 3 中的图像 2,2
    • Reach under the bridge to pull out the end of each string.
  4. Fender Jazz Bass Strings Replacement: 步骤 4 中的图像 1,2 Fender Jazz Bass Strings Replacement: 步骤 4 中的图像 2,2
    • Insert the end of the string with no knob on the bottom through the bridge first.
    • Pull each string through to the top of the neck.
  5. Fender Jazz Bass Strings Replacement: 步骤 5 中的图像 1,1
    • Insert the strings into the indentations on the nut.
    • Wrap the strings around the tuning pegs about two times.
  6. Fender Jazz Bass Strings Replacement: 步骤 6 中的图像 1,2 Fender Jazz Bass Strings Replacement: 步骤 6 中的图像 2,2
    • Tighten the tuning pegs until the bass is in tune.
    • The standard tuning for a bass is E A D G.
    • You will have excess string hanging off the pegs of the bass.
终点
另外一个人完成了本指南。
团队
CSU Los Angeles, Team 1-1, Briggs Spring 2022 CSU Los Angeles, Team 1-1, Briggs Spring 2022 的会员
CSULA-BRIGGS-S22S1G1
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 643
