跳转到主内容
加入维修社区 - 创建账户
Fairphone 3 Bottom Module Replacement
你所需要的
  1. Fairphone 3 Bottom Module Replacement, Back Cover: 步骤 1 中的图像 1,2 Fairphone 3 Bottom Module Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
    • Pry the back cover up to start separating its plastic clips.
    询问修复机器人
    添加评论
  2. Fairphone 3 Bottom Module Replacement: 步骤 2 中的图像 1,3 Fairphone 3 Bottom Module Replacement: 步骤 2 中的图像 2,3 Fairphone 3 Bottom Module Replacement: 步骤 2 中的图像 3,3
    • Slide around the bottom right corner of the back cover to loosen the lower plastic clips.
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • To reinstall the back cover press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
    询问修复机器人
    添加评论
  3. Fairphone 3 Bottom Module Replacement, Battery: 步骤 3 中的图像 1,2 Fairphone 3 Bottom Module Replacement, Battery: 步骤 3 中的图像 2,2
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
    • Lever the battery up until you can get a good grip.
    询问修复机器人
    添加评论
  4. Fairphone 3 Bottom Module Replacement: 步骤 4 中的图像 1,2 Fairphone 3 Bottom Module Replacement: 步骤 4 中的图像 2,2
    • Lift the battery out of its recess and remove it.
    询问修复机器人
    添加评论
  5. Fairphone 3 Bottom Module Replacement, Display Assembly: 步骤 5 中的图像 1,1
    • Whenever a Phillips #00 screw is mentioned you can also unfasten it with a size #0 bit/screwdriver.
    • Remove the thirteen Phillips #00 screws (4 mm length).
    添加评论
  6. Fairphone 3 Bottom Module Replacement: 步骤 6 中的图像 1,3 Fairphone 3 Bottom Module Replacement: 步骤 6 中的图像 2,3 Fairphone 3 Bottom Module Replacement: 步骤 6 中的图像 3,3
    • Make sure to insert the opening pick between the midframe and the display module and not into the small gap next to the screen. Otherwise you're going to pry up the screen instead of the whole display module.
    • Insert an opening pick between the midframe and the display module on the right edge of the phone.
    • Slide the opening pick down to the bottom right corner to pry open the plastic clamps of the display module.
    添加评论
  7. Fairphone 3 Bottom Module Replacement: 步骤 7 中的图像 1,2 Fairphone 3 Bottom Module Replacement: 步骤 7 中的图像 2,2
    • Slide the opening pick around the bottom right corner and use it to disengage the plastic clamps at the bottom of the display module.
    添加评论
  8. Fairphone 3 Bottom Module Replacement: 步骤 8 中的图像 1,2 Fairphone 3 Bottom Module Replacement: 步骤 8 中的图像 2,2
    • Slide the opening pick along the left side to pry the display module up.
    • The display module should pop out of the midframe during this process. In case it doesn’t, check for remaining clamps you might have missed.
    询问修复机器人
    添加评论
  9. Fairphone 3 Bottom Module Replacement: 步骤 9 中的图像 1,2 Fairphone 3 Bottom Module Replacement: 步骤 9 中的图像 2,2
    • Remove the display assembly.
    • To reinstall the display-module press it into place on all sides until you can hear a snap from the plastic clamps to make sure it sits flush with the frame.
    • If you install a new display: The new display module comes with a white plastic cover held by 2 screws over the processor and the connectors. This needs to be taken off.
    添加评论
  10. Fairphone 3 Bottom Module Replacement, Bottom Module: 步骤 10 中的图像 1,1
    • Remove the four 4.1mm-longPhillips #00 screws.
    询问修复机器人
    添加评论
  11. Fairphone 3 Bottom Module Replacement: 步骤 11 中的图像 1,2 Fairphone 3 Bottom Module Replacement: 步骤 11 中的图像 2,2
    • Use a spudger to pry up and disconnect the bottom module connecting cable.
    添加评论
  12. Fairphone 3 Bottom Module Replacement: 步骤 12 中的图像 1,2 Fairphone 3 Bottom Module Replacement: 步骤 12 中的图像 2,2
    • Use your fingers to remove the bottom module.
    添加评论
结论
Information on what to do with the old module can be found on the FairPhone support page and in the FairPhone forum.
取消:我没有完成这个指南。
44等其他人完成本指南。
Adriana Zwink
于12/18/19注册
67,206 声望
创作了167篇指南
团队
iFixit iFixit 的会员
Staff
122 名成员
创作了26,050篇指南
14指南评论
Spitze, jetzt lädt mein Fairphone 3 wieder tadellos. Tolle Anleitung!!!
Petra Breit - 回复 分享
Super, das freut uns!
Adriana Zwink - 回复 分享
Thanks for the guide, it was very helpful. However, I'm pretty sure we don't need to remove so many screws on Step 5.
I for one had a hard time removing one, and I left it in place, and I could achieve the repair without any problem.
I think only the 6 screws on the very outside edge, that correspond with the screen's locations for the screws.
mll - 回复 分享
Hello @mll, thank you for sharing your experience with us! We're glad that the repair worked out. I've rechecked the display and the phone assembly. All screws should be removed to make sure not to damage components of the phone. Feel free to check Fairphone's video on replacing the display unit: https://www.youtube.com/watch?v=hG6OVPTn...
@adrianazwink , you are right indeed, and I stand corrected.
mll - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 40
过去 30 天: 203
总计 22,670
