跳转到主内容
加入维修社区 - 创建账户
Fairphone 2 Rear Camera Module Replacement
你所需要的
  1. Fairphone 2 Rear Camera Module Replacement, Slim Case: 步骤 1 中的图像 1,3 Fairphone 2 Rear Camera Module Replacement, Slim Case: 步骤 1 中的图像 2,3 Fairphone 2 Rear Camera Module Replacement, Slim Case: 步骤 1 中的图像 3,3
    • Pick a corner of your slim case and get between the two parts with your thumb's fingernails.
    • Pull up the back part of the slim case to separate the small snap fit connections.
    • Remove the back part of the slim case.
    询问修复机器人
    添加评论
  2. Fairphone 2 Rear Camera Module Replacement: 步骤 2 中的图像 1,3 Fairphone 2 Rear Camera Module Replacement: 步骤 2 中的图像 2,3 Fairphone 2 Rear Camera Module Replacement: 步骤 2 中的图像 3,3
    • Get in between the front part of the slim case and the phone's body with your thumb nail.
    • Separate the snap fit connectors on the front part by pulling it to the side and pushing against the display.
    询问修复机器人
    添加评论
  3. Fairphone 2 Rear Camera Module Replacement: 步骤 3 中的图像 1,1
    • Remove the front part of the slim case.
    询问修复机器人
    添加评论
  4. Fairphone 2 Rear Camera Module Replacement, Battery: 步骤 4 中的图像 1,3 Fairphone 2 Rear Camera Module Replacement, Battery: 步骤 4 中的图像 2,3 Fairphone 2 Rear Camera Module Replacement, Battery: 步骤 4 中的图像 3,3
    • Push the battery toward the top of the phone.
    • Pull the battery out away from the phone.
    添加评论
  5. Fairphone 2 Rear Camera Module Replacement, Display Assembly: 步骤 5 中的图像 1,3 Fairphone 2 Rear Camera Module Replacement, Display Assembly: 步骤 5 中的图像 2,3 Fairphone 2 Rear Camera Module Replacement, Display Assembly: 步骤 5 中的图像 3,3
    • After taking out the battery you can unlock the display assembly.
    • Flip the two blue switches to the inner position.
    • Slide the display assembly towards the bottom of the phone.
    添加评论
    • Another possible way of sliding the display assembly open.
    添加评论
  6. Fairphone 2 Rear Camera Module Replacement: 步骤 7 中的图像 1,1
    • Take off the display assembly.
    询问修复机器人
    添加评论
  7. Fairphone 2 Rear Camera Module Replacement, Rear Camera Module: 步骤 8 中的图像 1,2 Fairphone 2 Rear Camera Module Replacement, Rear Camera Module: 步骤 8 中的图像 2,2
    • Remove the three Phillips #0 screws of the module which are nicely marked by the blue circles.
    • Now the module should stand off a little bit due to the pogo pins underneath.
    添加评论
  8. Fairphone 2 Rear Camera Module Replacement: 步骤 9 中的图像 1,1
    • Take out the whole module.
    添加评论
结论
Information on what to do with the old module can be found on the FairPhone support page and in the FairPhone forum.
取消:我没有完成这个指南。
71等其他人完成本指南。
Tobias Isakeit
于03/31/14注册
134,261 声望
创作了189篇指南
团队
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 的会员
Business
1 名成员
创作了1,164篇指南
23指南评论
Alles gut - hat wunderbar funktioniert, insbesondere dank des Videos für Schritt 4
Walter Strohschein - 回复 分享
Heel snelle levering van mijn nieuwe camera!
Het was ons (mijn man) vast niet gelukt zonder de goede begeleidende filmpjes!
Betty Bol
Betty - 回复 分享
die Variante mit slim case ist noch nicht berücksichtigt
Ansonsten: super Anleitung
W. Koch - 回复 分享
Hat prima funktioniert dank einfacher Anleitung und einfacher Bauweise.
Christian Heider - 回复 分享
Geschafft! - Schritt 4 war beim Slim Case nicht so einfach, aber nach ein paar Minuten hatte ich es raus. Ich frage mich bloss, was ich nun mit der alten Kamera mache..? Kann man die zurückschicken? Gibt es dazu irgendwelche Infos? Danke für die Anleitung und allfällige Infos bezüglich “Zukunft der alten Kamera” ;-) !
Claudia Serena Herrmann - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 37
总计 123,266
