跳转到主内容
加入维修社区 - 创建账户
Epson Powerlite 410W Lens Replacement
你所需要的
    1. Epson Powerlite 410W Lens Replacement, Top Cover: 步骤 1 中的图像 1,1
      • Press the power button located on top of the projector.
      • Remember to let the projector cool off completely after turning off the power before beginning the repair.
      询问修复机器人
      添加评论
    2. Epson Powerlite 410W Lens Replacement: 步骤 2 中的图像 1,1
      • Remove eight screws from the bottom of the device using a Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    3. Epson Powerlite 410W Lens Replacement: 步骤 3 中的图像 1,3 Epson Powerlite 410W Lens Replacement: 步骤 3 中的图像 2,3 Epson Powerlite 410W Lens Replacement: 步骤 3 中的图像 3,3
      • Turn the projector so the power button is on top.
      • Gently pull up the cover until it pops off.
      • Do not pull too far; a ribbon cable still connects the top cover to the motherboard.
      • Disconnect the ribbon cable that attaches the cover to the motherboard.
      • Remove the cover and place to the side.
      询问修复机器人
      添加评论
    1. Epson Powerlite 410W Lens Replacement, Motherboard: 步骤 4 中的图像 1,2 Epson Powerlite 410W Lens Replacement, Motherboard: 步骤 4 中的图像 2,2
      • Remove the two screws holding down the motherboard using a Phillips #00 screwdriver.
      • Remove the four screws holding down the I/O board using a Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    2. Epson Powerlite 410W Lens Replacement: 步骤 5 中的图像 1,1
      • Remove the seven cables that are running to the motherboard by pulling them out of their sockets.
      询问修复机器人
      添加评论
    3. Epson Powerlite 410W Lens Replacement: 步骤 6 中的图像 1,3 Epson Powerlite 410W Lens Replacement: 步骤 6 中的图像 2,3 Epson Powerlite 410W Lens Replacement: 步骤 6 中的图像 3,3
      在这个步骤中使用的工具:
      • Using a plastic opening tool, gently pry up the black tabs holding in the ribbon cables on the motherboard.
      • Using tweezers, gently pull the ribbon cables out of the sockets.
      询问修复机器人
      添加评论
    4. Epson Powerlite 410W Lens Replacement: 步骤 7 中的图像 1,1
      • Gently pull the motherboard up and tilt it back, revealing the last cable attached to the motherboard. Disconnect this cable.
      • Remove the motherboard from the projector.
      询问修复机器人
      添加评论
    1. Epson Powerlite 410W Lens Replacement, Lens: 步骤 8 中的图像 1,2 Epson Powerlite 410W Lens Replacement, Lens: 步骤 8 中的图像 2,2
      • Remove four 2.5 mm silver hex screws from the silver bracket.
      • Depending on your screwdriver size, a flexible bit extension may be required.
      询问修复机器人
      添加评论
    2. Epson Powerlite 410W Lens Replacement: 步骤 9 中的图像 1,2 Epson Powerlite 410W Lens Replacement: 步骤 9 中的图像 2,2
      • Remove the four silver screws from the base of the lens.
      询问修复机器人
      添加评论
    3. Epson Powerlite 410W Lens Replacement: 步骤 10 中的图像 1,2 Epson Powerlite 410W Lens Replacement: 步骤 10 中的图像 2,2
      • Pull the lens assembly out from the silver bracket.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 18
总计 526
