简介
Use the guide to help you replace the battery in your in a Envizen V100M.
你所需要的
Remove the two screws on the side of the tablet that hold the back cover in place using the ifixit PH00 screwdriver.
The two screws for the back cover are: 1.5mm diameter x 3.5mm long
在这个步骤中使用的工具:Tweezers$4.99
Remove the solder from the red and black wires from the battery attached to the motherboard. Here is a guide on how to solder.
Remove the red and black wire from the motherboard using tweezers. If tweezers are unable to remove the wires, heat can be used to loosen the solder allowing for the wires to be removed.
另外一个人完成了本指南。
