跳转到主内容
加入维修社区 - 创建账户
Ematic Genesis Battery Replacement
你所需要的
    1. Ematic Genesis Battery Replacement, Ematic Genesis Casing: 步骤 1 中的图像 1,3 Ematic Genesis Battery Replacement, Ematic Genesis Casing: 步骤 1 中的图像 2,3 Ematic Genesis Battery Replacement, Ematic Genesis Casing: 步骤 1 中的图像 3,3
      • Unscrew the two (2) 1.3mm Phillips #00 screws found on the bottom edge of the tablet, where the power and volume buttons are located.
      询问修复机器人
      添加评论
    2. Ematic Genesis Battery Replacement: 步骤 2 中的图像 1,3 Ematic Genesis Battery Replacement: 步骤 2 中的图像 2,3 Ematic Genesis Battery Replacement: 步骤 2 中的图像 3,3
      • Insert plastic opening tool into the edge between the screen plate and the back plate to create a separation between the casings.
      • Insert the flat end of the spudger next to the plastic opening tool and carefully pry the edges apart. Continue this all around the edges until the casings separate.
      • There may be cracking sounds when prying them apart. If carefully done, this is only the locks coming apart and is not harmful.
      • Be careful when separating the two plates as they are connected by the speaker wires and could be disconnected during this process.
      询问修复机器人
      添加评论
    3. Ematic Genesis Battery Replacement: 步骤 3 中的图像 1,1
      • Remove back plate from screen plate and lay both down flat next to each other.
      询问修复机器人
      添加评论
    1. Ematic Genesis Battery Replacement, Battery: 步骤 4 中的图像 1,3 Ematic Genesis Battery Replacement, Battery: 步骤 4 中的图像 2,3 Ematic Genesis Battery Replacement, Battery: 步骤 4 中的图像 3,3
      • Lift up the two pieces of tape holding the copper plate and the connector ribbon to the battery. Gently hold or place away from the battery.
      询问修复机器人
      添加评论
    2. Ematic Genesis Battery Replacement: 步骤 5 中的图像 1,3 Ematic Genesis Battery Replacement: 步骤 5 中的图像 2,3 Ematic Genesis Battery Replacement: 步骤 5 中的图像 3,3
      在这个步骤中使用的工具:
      Plastic Cards
      $2.99
      • Using a plastic card, gently break the adhesive that holds the battery to the metal screen plate.
      • The battery is very bendable. Although it may not be working, there are still dangerous contents inside batteries.
      询问修复机器人
      添加评论
    3. Ematic Genesis Battery Replacement: 步骤 6 中的图像 1,1
      • If replacing the battery, disconnect the wires that connect the battery to the motherboard.
      • If not replacing the battery, do NOT disconnect the wires.
      • To reconnect the new battery, a soldering kit will be necessary. Use the iFixit soldering guide to gain further information on how to complete this step.
      • 如何焊接和拆焊
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
Baylor, Team 4-3, Williams Spring 2015 Baylor, Team 4-3, Williams Spring 2015 的会员
BU-WILLIAMS-S15S4G3
3 名成员
创作了30篇指南
1指南评论
tienen el firmware disponible?
Danny Abreu Victoriano - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 13
过去 30 天: 45
总计 1,539
