跳转到主内容
加入维修社区 - 创建账户
Ematic FunTab 2 Motherboard Replacement
你所需要的
    1. Ematic FunTab 2 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
      • Remove back of Ematic FunTab by using the plastic opening tool to pry the back open.
      询问修复机器人
      添加评论
    2. Ematic FunTab 2 Motherboard Replacement: 步骤 2 中的图像 1,3 Ematic FunTab 2 Motherboard Replacement: 步骤 2 中的图像 2,3 Ematic FunTab 2 Motherboard Replacement: 步骤 2 中的图像 3,3
      • Next, you need to remove all connections to the motherboard and the device.
      • Start by first removing the tape from all the connections.
      • Be careful not to remove the camera.
      询问修复机器人
      添加评论
    3. Ematic FunTab 2 Motherboard Replacement: 步骤 3 中的图像 1,3 Ematic FunTab 2 Motherboard Replacement: 步骤 3 中的图像 2,3 Ematic FunTab 2 Motherboard Replacement: 步骤 3 中的图像 3,3
      • Remove LCD connector from the LCD.
      • Be sure to flip up the retaining tabs before pulling the LCD connector out. (It is the black tab on the connection port).
      询问修复机器人
      添加评论
    4. Ematic FunTab 2 Motherboard Replacement: 步骤 4 中的图像 1,1
      在这个步骤中使用的工具:
      • Remove camera connection from camera with tweezers.
      • Again, be sure to flip up the retaining tab before pulling the connector.
      询问修复机器人
      添加评论
    5. Ematic FunTab 2 Motherboard Replacement: 步骤 5 中的图像 1,1
      • Remove speaker connection from speaker with tweezers.
      • Before pulling the speaker connection make sure the retaining tab is flipped up.
      询问修复机器人
      添加评论
    6. Ematic FunTab 2 Motherboard Replacement: 步骤 6 中的图像 1,3 Ematic FunTab 2 Motherboard Replacement: 步骤 6 中的图像 2,3 Ematic FunTab 2 Motherboard Replacement: 步骤 6 中的图像 3,3
      • Remove wires:
      • Start by removing the black wire on each side.
      • Next, remove the WiFi antenna wire from the motherboard.
      • Finally, remove the yellow, red, and black wires.
      • To put the wires back in their correct locations you will need a soldering iron to solder the wire back in place. You will do this once the motherboard is replaced. Here is a guide on how to solder 如何焊接和拆焊
      询问修复机器人
      添加评论
    7. Ematic FunTab 2 Motherboard Replacement: 步骤 7 中的图像 1,3 Ematic FunTab 2 Motherboard Replacement: 步骤 7 中的图像 2,3 Ematic FunTab 2 Motherboard Replacement: 步骤 7 中的图像 3,3
      • Unscrew all four screws on motherboard with the Phillip's head screwdriver.
      • All of the screws are the same size, and should all fit in either corresponding screw location.
      询问修复机器人
      添加评论
    8. Ematic FunTab 2 Motherboard Replacement: 步骤 8 中的图像 1,2 Ematic FunTab 2 Motherboard Replacement: 步骤 8 中的图像 2,2
      • It is now safe to remove and replace the old motherboard with your new motherboard.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 33
总计 1,454
