简介
If your battery is no longer charging or holding a charge you may need to replace it, in this guide you will learn exactly how to replace the battery in your tablet.
你所需要的
There are two screws on the side with the micro USB power port. Remove the two 2mm x 0.5mm screws with a Phillips #0 Screwdriver head.
在这个步骤中使用的工具:Plastic Cards$2.99
4. Remove the tape holding the battery to the plastic frame. The battery is glued to the back of the LED. Pry the battery off the LED using a plastic card.
To reassemble your device, follow these instructions in reverse order. Note, you need to solder the battery wires onto the motherboard.
2等其他人完成本指南。
