跳转到主内容
Eluktronics N850HK SSD Replacement
Brandon Yuan
Brandon Yuan 另一个贡献者
最后更新于 September 21, 2024
10 - 20 分钟
中等
The Eluktronics N850HK is a laptop model equipped with an M.2 PCIe SSD. The SSD is a storage device, used to store the data in a laptop. Removing the SSD from the laptop is necessary to check for damages, or to replace the card. Replacing a laptop's SSD can yield greater storage space and higher reading/writing speeds.
Replacing the SSD in the N850HK is a simple task that can be accomplished with just a screwdriver and some careful handling. This guide will cover the replacement of the SSD in this laptop model.
Before you begin this repair, power off your laptop and unplug it from the power cord. For an additional safety measure, disconnect or remove the battery prior to the repair.
你所需要的
工具
查看更多...
  1. Eluktronics N850HK SSD Replacement, SSD: 步骤 1 中的图像 1,3 Eluktronics N850HK SSD Replacement, SSD: 步骤 1 中的图像 2,3 Eluktronics N850HK SSD Replacement, SSD: 步骤 1 中的图像 3,3
    • Push both switch locks inward to unlock the battery from the bottom panel.
    • The switch on the left must be held in place.
    • Remove the battery from the back of the laptop.
  2. Eluktronics N850HK SSD Replacement: 步骤 2 中的图像 1,2 Eluktronics N850HK SSD Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the twelve 4 mm screws from the bottom panel of the laptop.
  3. Eluktronics N850HK SSD Replacement: 步骤 3 中的图像 1,2 Eluktronics N850HK SSD Replacement: 步骤 3 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the four 3 mm screws located under where the battery usually rests.
    • Do not remove the two additional screws near the bottom screw. These are connected to the motherboard and do not need to be removed.
  4. Eluktronics N850HK SSD Replacement: 步骤 4 中的图像 1,2 Eluktronics N850HK SSD Replacement: 步骤 4 中的图像 2,2
    • Lift the back case off and identify the SSD in the lower right corner.
    • Although the chances of damage are low, it is important to be aware of static electricity in your surroundings when working a computer motherboard. Ground yourself or use an anti-static wrist strap.
  5. Eluktronics N850HK SSD Replacement: 步骤 5 中的图像 1,3 Eluktronics N850HK SSD Replacement: 步骤 5 中的图像 2,3 Eluktronics N850HK SSD Replacement: 步骤 5 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove 3 mm screw securing the SSD.
    • The SSD will naturally lift by a few millimeters.
    • Carefully slide the SSD from the M.2 slot.
  6. Eluktronics N850HK SSD Replacement: 步骤 6 中的图像 1,3 Eluktronics N850HK SSD Replacement: 步骤 6 中的图像 2,3 Eluktronics N850HK SSD Replacement: 步骤 6 中的图像 3,3
    • Use the ridges on the right side to align the SSD properly.
    • Slide the new SSD into the M.2 mounting slot.
    • Use the Phillips #00 screwdriver to replace the 3 mm screw that secures the SSD.
  7. Eluktronics N850HK SSD Replacement: 步骤 7 中的图像 1,3 Eluktronics N850HK SSD Replacement: 步骤 7 中的图像 2,3 Eluktronics N850HK SSD Replacement: 步骤 7 中的图像 3,3
    • Reassemble by following the directions in reverse order.
结论
Alternative models where this guide may still apply:
  • Eluktronics N857HK1
  • Eluktronics N850HP6
3等其他人完成本指南。
Brandon Yuan
于06/22/24注册
196 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 101
过去 30 天: 555
总计 1,873
