跳转到主内容
DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement
你所需要的
  1. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Check your controller model: 步骤 1 中的图像 1,1
    • Check the model number on the back of your controller. This guide was written using model CUH-ZCT1U. If you have another model, the guide procedure and replacement parts may differ slightly.
    • If you have the second generation DualShock 4, model CUH-ZCT2U, use these guides.
  2. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Unfasten the rear case: 步骤 2 中的图像 1,2 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Unfasten the rear case: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    Microfiber Cleaning Cloths
    $3.99
    • If you need to stabilize your controller during this repair, lay it on a soft surface such as a microfiber cloth.
    • Use a Phillips screwdriver to remove the four 6.4 mm-long screws securing the rear case.
  3. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the L1 button: 步骤 3 中的图像 1,3 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the L1 button: 步骤 3 中的图像 2,3 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the L1 button: 步骤 3 中的图像 3,3
    • Use an opening pick to pry each corner of the L1 button from the front case.
    • Cover the button to prevent it from ejecting out of your workspace.
    • Remove the button.
  4. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the R1 button: 步骤 4 中的图像 1,1
    • Use your opening pick to pry and remove the R1 button, just as you did for the L1 button.
  5. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Unclip the rear case: 步骤 5 中的图像 1,3 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Unclip the rear case: 步骤 5 中的图像 2,3 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Unclip the rear case: 步骤 5 中的图像 3,3
    • Six plastic clips secure the rear case to the front case. The next four steps demonstrate how to release these clips before you can open the controller.
    • Insert your opening pick at a downward angle between the front case and rear case, halfway between the handle and the action buttons.
    • Slide your pick toward the handle and pry up to release the first clip.
    • Repeat this procedure on the other side of the controller to release the second clip.
  6. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: 步骤 6 中的图像 1,3 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: 步骤 6 中的图像 2,3 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: 步骤 6 中的图像 3,3
    • Two more clips secure the rear case near the extension port and the headphone jack.
    • Insert your opening pick between the front case and rear case at either side of the ports.
    • Twist your pick to unclip this section of the rear case from the front case.
    • If the rear case feels stuck, insert and twist your pick from different angles.
    • Don't open the controller yet, as it's still held together by two very delicate clips near the triggers.
  7. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: 步骤 7 中的图像 1,1
    • The final two clips are very delicate, and must be disengaged from inside the controller. If you break them, don't worry—it won't affect this repair or your controllers functionality.
    • Locate the clips by looking through the gap above the R2 or L2 buttons.
  8. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: 步骤 8 中的图像 1,3 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: 步骤 8 中的图像 2,3 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: 步骤 8 中的图像 3,3
    • Insert the point of a spudger through the gap above the R2 button and push the retaining clip outward.
    • While pushing the clip outward, slowly pull the rear case away from the front case until you feel them separate.
    • Don't fully open the controller until each of the R2 and L2 clips have been disengaged.
    • Repeat this procedure for the clip near the L2 button.
  9. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the rear case: 步骤 9 中的图像 1,3 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the rear case: 步骤 9 中的图像 2,3 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the rear case: 步骤 9 中的图像 3,3
    • Press the R2 button and slide the rear case over it.
  10. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: 步骤 10 中的图像 1,1
    • Press the L2 button and slide the rear case over it.
  11. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: 步骤 11 中的图像 1,3 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: 步骤 11 中的图像 2,3 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: 步骤 11 中的图像 3,3
    • Flip the rear case over the top of the controller and lay it down, being careful not to strain the interconnect cable.
  12. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Disconnect the interconnect cable: 步骤 12 中的图像 1,3 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Disconnect the interconnect cable: 步骤 12 中的图像 2,3 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Disconnect the interconnect cable: 步骤 12 中的图像 3,3
    在这个步骤中使用的工具:
    • Use tweezers or your fingers to remove the interconnect cable by pulling its blue pull tab straight out of the socket.
    • During reassembly, reconnect the cable with its blue pull tab facing the outside of the controller.
  13. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Disconnect the battery: 步骤 13 中的图像 1,2 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Disconnect the battery: 步骤 13 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers or your fingers to grab and disconnect the head of the battery cable from the motherboard.
    • Only pull on the head of the connector—don't pull on the cable itself.
  14. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the battery: 步骤 14 中的图像 1,1
    • Remove the battery.
  15. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the reset button extension: 步骤 15 中的图像 1,2 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the reset button extension: 步骤 15 中的图像 2,2
    • Grab and remove the reset button extension from its recess in the battery bracket.
  16. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the battery bracket: 步骤 16 中的图像 1,3 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the battery bracket: 步骤 16 中的图像 2,3 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the battery bracket: 步骤 16 中的图像 3,3
    • Locate the two clips securing the battery bracket to the motherboard.
    • Insert the point of your spudger into the opening behind the right bracket clip.
    • Depress the clip to disengage it from the motherboard.
    • Lift up the right edge of the battery bracket.
  17. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: 步骤 17 中的图像 1,2 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: 步骤 17 中的图像 2,2
    • Insert the point of your spudger in the opening behind the left bracket clip.
    • Remove the battery bracket.
  18. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Disconnect the touch pad: 步骤 18 中的图像 1,3 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Disconnect the touch pad: 步骤 18 中的图像 2,3 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Disconnect the touch pad: 步骤 18 中的图像 3,3
    在这个步骤中使用的工具:
    • Use the point of your spudger to flip up the locking flap securing the touch pad cable ZIF connector.
    • Use tweezers or your fingers to disconnect the cable using its blue pull tab.
  19. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Unfasten the motherboard: 步骤 19 中的图像 1,1
    • Use your Phillips screwdriver to remove the 6.4 mm screw securing the motherboard.
    • During reassembly, hold the motherboard tight to the front case before fastening it. Test each button to ensure the silicone button pads are properly aligned. If each button presses as expected, fasten the motherboard.
  20. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the midframe: 步骤 20 中的图像 1,2 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the midframe: 步骤 20 中的图像 2,2
    • Grab the midframe by its plastic protrusions or the vibration motors and remove it.
    • Be careful not to separate the motherboard from the midframe, as they're only connected to each other by the vibration motor cables.
    • During reassembly, take your time positioning the midframe. Use the alignment posts to help guide it into place, and make sure the touch pad cable doesn't become trapped underneath.
  21. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the motherboard: 步骤 21 中的图像 1,2 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the motherboard: 步骤 21 中的图像 2,2
    • Be careful not to strain the vibration motor cables. Follow this guide to re-solder the vibration motors if they break off the motherboard.
    • Lift the motherboard and flip it over the bottom of the midframe, leaving the vibration motor cables attached.
  22. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the R2 button: 步骤 22 中的图像 1,3 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the R2 button: 步骤 22 中的图像 2,3 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the R2 button: 步骤 22 中的图像 3,3
    • Firmly grip the R2 button and unclip each peg from the midframe.
    • The spring may eject from the inside peg. Be careful not to lose it.
    • Remove the R2 button.
  23. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the L2 button: 步骤 23 中的图像 1,1
    • Unclip the L2 button from the midframe and remove it, making sure not to lose the small spring from the inside peg.
  24. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Reassembly information: 步骤 24 中的图像 1,3 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Reassembly information: 步骤 24 中的图像 2,3 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Reassembly information: 步骤 24 中的图像 3,3
    • During reassembly, follow these instructions to install the springs onto the R2 and L2 buttons:
    • Lay the midframe face-down and orient the button properly.
    • Place the spring over the inside peg with its bent ends facing upward.
    • Rest one end of the spring in its channel in the button.
    • Place the button over its clips and rest the other end of the spring in its channel in the midframe.
    • Press the button's pegs into their clips until they snap into place.
  25. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the silicone button pads: 步骤 25 中的图像 1,3 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the silicone button pads: 步骤 25 中的图像 2,3 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the silicone button pads: 步骤 25 中的图像 3,3
    • Grab the upper edge of the R1 and R2 button pad.
    • Slide the pad out of its channel in the midframe.
  26. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: 步骤 26 中的图像 1,3 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: 步骤 26 中的图像 2,3 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: 步骤 26 中的图像 3,3
    • Slide the L1 and L2 button pad out of its channel in the midframe and remove it.
    • Each pad has two plugs and an upper groove to align it with the midframe. During reassembly, ensure the plugs are inserted in their holes and the groove is hooked onto the tab in the midframe.
  27. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Loosen the button circuit membrane: 步骤 27 中的图像 1,3 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Loosen the button circuit membrane: 步骤 27 中的图像 2,3 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Loosen the button circuit membrane: 步骤 27 中的图像 3,3
    在这个步骤中使用的工具:
    • Use tweezers or the point of a spudger to lift the underside of the R1 and R2 section of the button circuit membrane.
    • Slide the membrane over its retaining tab on the midframe.
    • During reassembly, slide the membrane into its slot until it snaps into place over its retaining tab.
  28. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: 步骤 28 中的图像 1,3 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: 步骤 28 中的图像 2,3 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: 步骤 28 中的图像 3,3
    • Use tweezers or the point of a spudger to lift the underside of the L1 and L2 section of the button circuit membrane.
  29. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: 步骤 29 中的图像 1,2 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: 步骤 29 中的图像 2,2
    • Peel and lift the middle section of the button circuit membrane from its retaining pegs on the back of the midframe.
  30. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: 步骤 30 中的图像 1,3 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: 步骤 30 中的图像 2,3 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: 步骤 30 中的图像 3,3
    • Flip the midframe over so the button circuit membrane is facing you.
    • Unclip the right half of the button circuit membrane from its two retaining pegs on the face of the midframe.
  31. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: 步骤 31 中的图像 1,3 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: 步骤 31 中的图像 2,3 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement: 步骤 31 中的图像 3,3
    • Unclip the left half of the button circuit membrane from its two retaining pegs on the face of the midframe.
  32. DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the button circuit membrane: 步骤 32 中的图像 1,2 DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement, Remove the button circuit membrane: 步骤 32 中的图像 2,2
    • Grab each side of the button circuit membrane.
    • Feed the middle section of the membrane through its cutout in the midframe.
    • Remove the membrane.
结论
15等其他人完成本指南。
Clay Eickemeyer
于09/19/22注册
95,257 声望
创作了465篇指南
9指南评论
I’ve changed two flex boards from two different sellers, and I keep having a battery drain of about 25mA after i installed them. The battery drain is not present with the original flex board, any ideas?
Alessandro - 回复
Ok no, little update. the battery drain is present even if I disconnect the flex board, the touch connector and the led . It’s something on the main board I think, but I can’t figure out what is it. Is there some insulation that I may have lost when changing the flex board the first time?
Alessandro -
That sounds really weird. I don’t remember any insulation on this specific model of controller. I don’t have this anymore as it was a repair for a friend and I also hadn’t noticed or measured such a drain.
Devnol -
The only other thing I can think of is a failure on one of the components soldered on the main board, but 20mA in standby condition are VERY high!
Alessandro - 回复
The warning regarding the rumblers being hard soldered and the wiring is delicate honestly should be in step 4, jiggling joysticks to remove the front cover can easily cause the rumblers to be disconnected and require some time consuming resoldering to reattach them.
sefog - 回复
添加评论
浏览统计数据:
过去 24 小时: 13
过去 7 天: 104
过去 30 天: 523
总计 36,562
