跳转到主内容
加入维修社区 - 创建账户
DualShock 3 Buttons Replacement
你所需要的
    1. DualShock 3 Buttons Replacement, Rear Cover: 步骤 1 中的图像 1,1
      • Remove the five 7.2 mm Phillips screws securing the rear cover to the controller.
      添加评论
    2. DualShock 3 Buttons Replacement: 步骤 2 中的图像 1,1
      • Press on the rear cover between the analog sticks and slightly lift the lower edge of it away from the rest of the controller.
      添加评论
    3. DualShock 3 Buttons Replacement: 步骤 3 中的图像 1,2 DualShock 3 Buttons Replacement: 步骤 3 中的图像 2,2
      • Push the rear cover slightly toward the top edge of the controller to clear the front edge of the #2 triggers.
      • Pull the rear cover away from the rest of the controller, being careful not to pop off the #2 triggers.
      • If you happen to accidentally pop off the trigger buttons, we have a trigger button guide to reattach them.
      添加评论
    1. DualShock 3 Buttons Replacement, Battery: 步骤 4 中的图像 1,1
      • Lift the battery off the motherboard for enough clearance to access the battery connector.
      询问修复机器人
      添加评论
    2. DualShock 3 Buttons Replacement: 步骤 5 中的图像 1,1
      在这个步骤中使用的工具:
      • Carefully pull the battery connector away from its socket on the motherboard.
      • It may be helpful to use a pair of tweezers or pliers to grab the battery connector when you disconnect it for the first time. Only pull on the connector. Do not try to remove by pulling on the red and black wires.
      添加评论
    1. DualShock 3 Buttons Replacement, Motherboard Assembly: 步骤 6 中的图像 1,1
      • Remove the single 7.2 mm Phillips screw securing the motherboard to the front cover.
      添加评论
    2. DualShock 3 Buttons Replacement: 步骤 7 中的图像 1,3 DualShock 3 Buttons Replacement: 步骤 7 中的图像 2,3 DualShock 3 Buttons Replacement: 步骤 7 中的图像 3,3
      • Slide the trigger button retainers slightly away from the front cover.
      • Remove the #1 button on both sides.
      询问修复机器人
      添加评论
    3. DualShock 3 Buttons Replacement: 步骤 8 中的图像 1,2 DualShock 3 Buttons Replacement: 步骤 8 中的图像 2,2
      • Pull the vibration motor retainers away from the front cover to dislodge the motherboard assembly.
      添加评论
    4. DualShock 3 Buttons Replacement: 步骤 9 中的图像 1,1
      • Remove the motherboard assembly from the front cover.
      • When removing the motherboard assembly, try not to tilt the front cover upside down as the buttons and their covers may fall out.
      添加评论
    1. DualShock 3 Buttons Replacement, Buttons: 步骤 10 中的图像 1,2 DualShock 3 Buttons Replacement, Buttons: 步骤 10 中的图像 2,2
      • Lift the rubber button contacts off the front controller cover to access the plastic button covers.
      • Lift any damaged plastic button covers out of the controller cover.
      添加评论
    2. DualShock 3 Buttons Replacement: 步骤 11 中的图像 1,1
      • The D-pad has a three-armed plastic piece that must be installed as shown before installing the rubber button pad for it to work properly.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
110等其他人完成本指南。
6指南评论
My Dualshock 3 didn't have the three armed plastic piece on the D-pad. Mine's a red one, relatively recent. My controller also had the problem where it would randomly send button press events when using the L-stick. I traced the problem to the ribbon connector between the board and the contacts, which was very dirty. I cleaned the contacts and put the controller back together with an additional rubber shim between the back cover and the battery, which got rid of the creakiness of the somewhat loose-fitting case. Works great now.
Kevin - 回复 分享
How do you clean the contacts? Is there a special way?
yeshuabendavid - 回复 分享
Thanks. ^^ Tightened screws after opening it and this kind of problem got solved.
Janne K - 回复 分享
Are these instructions the same for the dual-shock 2?
Larry Howard - 回复 分享
TNX-could not really figure out where the 3-armed plastic should fit in but tnx to step 11 i know-now im going to dismantle my controller again.
Kristian Brandström - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 34
过去 7 天: 141
过去 30 天: 586
总计 173,744
