跳转到主内容
加入维修社区 - 创建账户
DualSense Controller V5 Microphone Replacement
你所需要的
  1. DualSense Controller V5 Microphone Replacement, Unclip the right end of the middle trim: 步骤 1 中的图像 1,2 DualSense Controller V5 Microphone Replacement, Unclip the right end of the middle trim: 步骤 1 中的图像 2,2
    • Disconnect and power down your controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. DualSense Controller V5 Microphone Replacement, Unclip the lower-right edge of the middle trim: 步骤 2 中的图像 1,3 DualSense Controller V5 Microphone Replacement, Unclip the lower-right edge of the middle trim: 步骤 2 中的图像 2,3 DualSense Controller V5 Microphone Replacement, Unclip the lower-right edge of the middle trim: 步骤 2 中的图像 3,3
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. DualSense Controller V5 Microphone Replacement, Unclip the left end of the middle trim: 步骤 3 中的图像 1,2 DualSense Controller V5 Microphone Replacement, Unclip the left end of the middle trim: 步骤 3 中的图像 2,2
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. DualSense Controller V5 Microphone Replacement, Unclip the lower-left edge of the middle trim: 步骤 4 中的图像 1,3 DualSense Controller V5 Microphone Replacement, Unclip the lower-left edge of the middle trim: 步骤 4 中的图像 2,3 DualSense Controller V5 Microphone Replacement, Unclip the lower-left edge of the middle trim: 步骤 4 中的图像 3,3
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. DualSense Controller V5 Microphone Replacement, Remove the middle trim: 步骤 5 中的图像 1,3 DualSense Controller V5 Microphone Replacement, Remove the middle trim: 步骤 5 中的图像 2,3 DualSense Controller V5 Microphone Replacement, Remove the middle trim: 步骤 5 中的图像 3,3
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
  6. DualSense Controller V5 Microphone Replacement, Remove the L1 button: 步骤 6 中的图像 1,3 DualSense Controller V5 Microphone Replacement, Remove the L1 button: 步骤 6 中的图像 2,3 DualSense Controller V5 Microphone Replacement, Remove the L1 button: 步骤 6 中的图像 3,3
    • With one hand, grip the controller and use your thumb to hold down the left trigger.
    • With your free hand, insert the flat end of a spudger between the L1 and L2 buttons.
    • Use the spudger to gently pry the L1 button away from the controller and remove it, holding your finger over the button so it doesn't eject.
  7. DualSense Controller V5 Microphone Replacement, Remove the R1 button: 步骤 7 中的图像 1,3 DualSense Controller V5 Microphone Replacement, Remove the R1 button: 步骤 7 中的图像 2,3 DualSense Controller V5 Microphone Replacement, Remove the R1 button: 步骤 7 中的图像 3,3
    • Repeat the previous step to remove the R1 button.
  8. DualSense Controller V5 Microphone Replacement, Remove the rear case screws: 步骤 8 中的图像 1,2 DualSense Controller V5 Microphone Replacement, Remove the rear case screws: 步骤 8 中的图像 2,2
    • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the bottom corners of the lower case.
  9. DualSense Controller V5 Microphone Replacement: 步骤 9 中的图像 1,2 DualSense Controller V5 Microphone Replacement: 步骤 9 中的图像 2,2
    • Use a Phillips screwdriver to remove the two 6.4 mm screws behind the L1 and R1 buttons.
  10. DualSense Controller V5 Microphone Replacement, Separate the rear case: 步骤 10 中的图像 1,3 DualSense Controller V5 Microphone Replacement, Separate the rear case: 步骤 10 中的图像 2,3 DualSense Controller V5 Microphone Replacement, Separate the rear case: 步骤 10 中的图像 3,3
    • Be gentle when releasing the rear cover clips—they're delicate and can easily break.
    • Use the point of a spudger to release the two clips on either side of the headset jack.
  11. DualSense Controller V5 Microphone Replacement: 步骤 11 中的图像 1,3 DualSense Controller V5 Microphone Replacement: 步骤 11 中的图像 2,3 DualSense Controller V5 Microphone Replacement: 步骤 11 中的图像 3,3
    • Tight plastic clips secure the left and right edges of the rear case.
    • Insert the flat end of a spudger between the front and rear shells near the bottom of the left edge.
    • Slide the spudger along the left edge and gently pry the shells apart to release the clips.
  12. DualSense Controller V5 Microphone Replacement: 步骤 12 中的图像 1,3 DualSense Controller V5 Microphone Replacement: 步骤 12 中的图像 2,3 DualSense Controller V5 Microphone Replacement: 步骤 12 中的图像 3,3
    • Repeat the previous step on the right edge to release its clips.
  13. DualSense Controller V5 Microphone Replacement: 步骤 13 中的图像 1,2 DualSense Controller V5 Microphone Replacement: 步骤 13 中的图像 2,2
    • Lay your controller upside down so the joysticks are on your work surface.
    • Hold the controller down with your fingers and use your thumbs to lift the rear case away from the controller to fully separate it.
  14. DualSense Controller V5 Microphone Replacement, Remove the rear case: 步骤 14 中的图像 1,1
    • Remove the rear case.
  15. DualSense Controller V5 Microphone Replacement, Disconnect the battery: 步骤 15 中的图像 1,2 DualSense Controller V5 Microphone Replacement, Disconnect the battery: 步骤 15 中的图像 2,2
    • Don't try to fully remove the battery, as it's still connected to the controller by delicate cables.
    • Swing the battery out of its recess so you can access its connector, making sure to not strain the cables.
    • Keep the battery supported so it doesn't fall during the next step.
  16. DualSense Controller V5 Microphone Replacement: 步骤 16 中的图像 1,3 DualSense Controller V5 Microphone Replacement: 步骤 16 中的图像 2,3 DualSense Controller V5 Microphone Replacement: 步骤 16 中的图像 3,3
    • Use a pair of angled tweezers to firmly grip the short sides of the battery connector.
    • To get a stronger hold on the connector, grip the tweezers as close to the connector as you can.
    • Rock the connector side‑to‑side to walk it out of its socket and disconnect it.
  17. DualSense Controller V5 Microphone Replacement, Remove the battery: 步骤 17 中的图像 1,1
    • Remove the battery.
  18. DualSense Controller V5 Microphone Replacement, Remove the lower microphone: 步骤 18 中的图像 1,2 DualSense Controller V5 Microphone Replacement, Remove the lower microphone: 步骤 18 中的图像 2,2
    • Use tweezers to grip the lower microphone cable's plastic tab and pull it straight out of the socket to remove the microphone.
    • During reassembly, make sure the microphone has its rubber gasket and that the alignment tab goes into its cutout.
  19. DualSense Controller V5 Microphone Replacement, Remove the battery bracket: 步骤 19 中的图像 1,2 DualSense Controller V5 Microphone Replacement, Remove the battery bracket: 步骤 19 中的图像 2,2
    • Use a Phillips screwdriver to remove the 6.5 mm‑long screw securing the battery bracket.
  20. DualSense Controller V5 Microphone Replacement: 步骤 20 中的图像 1,2 DualSense Controller V5 Microphone Replacement: 步骤 20 中的图像 2,2
    • Remove the battery bracket.
  21. DualSense Controller V5 Microphone Replacement, Disconnect the motherboard: 步骤 21 中的图像 1,2 DualSense Controller V5 Microphone Replacement, Disconnect the motherboard: 步骤 21 中的图像 2,2
    • Use tweezers to grip the hard plastic section of the right trigger ribbon cable and pull the cable straight out of its socket to disconnect it.
    • If you're having trouble, try gripping the tweezers as close to the cable as possible to get a better hold.
  22. DualSense Controller V5 Microphone Replacement: 步骤 22 中的图像 1,3 DualSense Controller V5 Microphone Replacement: 步骤 22 中的图像 2,3 DualSense Controller V5 Microphone Replacement: 步骤 22 中的图像 3,3
  23. DualSense Controller V5 Microphone Replacement, Reposition the motherboard: 步骤 23 中的图像 1,2 DualSense Controller V5 Microphone Replacement, Reposition the motherboard: 步骤 23 中的图像 2,2
    • Throughout the rest of your repair, be very careful not to strain the delicate wires attached to the bottom edge of the board. They can easily tear, requiring soldering to fix them.
    • Use your fingers to gently push the joysticks through their cutouts on the shell to separate the motherboard.
  24. DualSense Controller V5 Microphone Replacement: 步骤 24 中的图像 1,2 DualSense Controller V5 Microphone Replacement: 步骤 24 中的图像 2,2
    • Carefully flip the motherboard down so the joysticks are facing up.
  25. DualSense Controller V5 Microphone Replacement, Speaker note: 步骤 25 中的图像 1,2 DualSense Controller V5 Microphone Replacement, Speaker note: 步骤 25 中的图像 2,2
    • The speaker may have fallen out when repositioning the motherboard. If it did, set it aside for reassembly. If it stayed in place on the motherboard or is in its recess in the front case, you can leave it in place.
    • During reassembly, place the speaker in its recess so the foam pad is on the left and the spring contacts are on the right.
  26. DualSense Controller V5 Microphone Replacement, Flip the controller over: 步骤 26 中的图像 1,2 DualSense Controller V5 Microphone Replacement, Flip the controller over: 步骤 26 中的图像 2,2
    • Grip the controller in one hand and motherboard in the other and carefully flip them over.
  27. DualSense Controller V5 Microphone Replacement, Remove the upper microphone: 步骤 27 中的图像 1,2 DualSense Controller V5 Microphone Replacement, Remove the upper microphone: 步骤 27 中的图像 2,2
    • Use tweezers to remove the upper microphone, threading its cable through the cutout in the case.
结论
Spencer Day
于09/14/22注册
163,046 声望
创作了1,043篇指南
团队
iFixit iFixit 的会员
Staff
124 名成员
创作了24,218篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 35
过去 30 天: 162
总计 600
