跳转到主内容
Disassembling Yamaha YPG-225 Faceplate
Lonnie Bissmeyer
Lonnie Bissmeyer5 其他贡献者
最后更新于 August 15, 2019
10分钟
简单
需要更好的图片
Removing the face plate is necessary for most repairs to this device. Removing the face plate is a relatively simple process, requiring only the removal of several screws.
你所需要的
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. Disassembling Yamaha YPG-225 Faceplate, Batteries: 步骤 1 中的图像 1,1
    • Turn the keyboard over so that the keys are facing the ground.
  2. Disassembling Yamaha YPG-225 Faceplate: 步骤 2 中的图像 1,1
    • Pop the tabs on the battery casing and remove it from the back plate.
  3. Disassembling Yamaha YPG-225 Faceplate: 步骤 3 中的图像 1,1
    • Locate the six batteries and remove them from the battery cavity.
  4. Disassembling Yamaha YPG-225 Faceplate, Faceplate: 步骤 4 中的图像 1,1
    • Remove the six 10mm screws at the top of the backplate.
  5. Disassembling Yamaha YPG-225 Faceplate: 步骤 5 中的图像 1,1
    • Remove the seven 12mm screws in the middle of the back plate.
  6. Disassembling Yamaha YPG-225 Faceplate: 步骤 6 中的图像 1,1
    • Remove the eight 10mm screws from the side and the bottom of the back plate.
  7. Disassembling Yamaha YPG-225 Faceplate: 步骤 7 中的图像 1,1
    • As the face plate is no longer connected to the body of the keyboard, be careful to not drop the body when performing this step.
    • Flip over the keyboard.
  8. Disassembling Yamaha YPG-225 Faceplate: 步骤 8 中的图像 1,2 Disassembling Yamaha YPG-225 Faceplate: 步骤 8 中的图像 2,2
    • Lifting from the front and the back of the face plate equally, pull the face plate up and then back, away from the keyboard.
    • Be careful when removing the face plate. There are wires attached.
结论
团队
Cal Poly, Team 2-62, Propen Fall 2012 Cal Poly, Team 2-62, Propen Fall 2012 的会员
CPSU-PROPEN-F12S2G62
2 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 10
总计 1,716
