跳转到主内容
Disassembling Nokia E71 Complete disassembly
Jose Gustavo Abreu Murta
Jose Gustavo Abreu Murta3 其他贡献者
最后更新于 February 8, 2021
30分钟
中等
社区贡献指南
你所需要的
工具
查看更多...
  1. Disassembling Nokia E71 Complete disassembly, Disassembling Nokia E71 Complete disassembly: 步骤 1 中的图像 1,1
    • First remove back cover, battery, chip and memory card .
  2. Disassembling Nokia E71 Complete disassembly: 步骤 2 中的图像 1,2 Disassembling Nokia E71 Complete disassembly: 步骤 2 中的图像 2,2
    • Remove 4 Torx T5 screws.
    the Screws can be TX4
    Stephan - 回复
  3. Disassembling Nokia E71 Complete disassembly: 步骤 3 中的图像 1,2 Disassembling Nokia E71 Complete disassembly: 步骤 3 中的图像 2,2
    • Press these four latches (each side has two) to open front cover.
  4. Disassembling Nokia E71 Complete disassembly: 步骤 4 中的图像 1,1
    • Carefully remove the front cover with blade tool.
  5. Disassembling Nokia E71 Complete disassembly: 步骤 5 中的图像 1,2 Disassembling Nokia E71 Complete disassembly: 步骤 5 中的图像 2,2
    • Carefully remove the bottom cover. This cover has no screws, only latches.
  6. Disassembling Nokia E71 Complete disassembly: 步骤 6 中的图像 1,1
    • Front cover, rubber keyboard and bottom cover removed.
  7. Disassembling Nokia E71 Complete disassembly: 步骤 7 中的图像 1,2 Disassembling Nokia E71 Complete disassembly: 步骤 7 中的图像 2,2
    • Remove these two Torx T6 screws at top of the smartphone.
    These screws can also TX4
    Stephan - 回复
  8. Disassembling Nokia E71 Complete disassembly: 步骤 8 中的图像 1,1
    • Carefully remove the assembly. Dont forget to move away the plastic clip holding the assembly down. You can find this in the center on the bottom.
  9. Disassembling Nokia E71 Complete disassembly: 步骤 9 中的图像 1,1
    • Base assembly with small connectors and parts.
  10. Disassembling Nokia E71 Complete disassembly: 步骤 10 中的图像 1,1
    • Remove the LCD connector.
  11. Disassembling Nokia E71 Complete disassembly: 步骤 11 中的图像 1,1
    • Carefully open the LCD and keyboard assembly, and remove keyboard connector.
  12. Disassembling Nokia E71 Complete disassembly: 步骤 12 中的图像 1,2 Disassembling Nokia E71 Complete disassembly: 步骤 12 中的图像 2,2
    • Both sides of the LCD and keyboard assembly removed.
  13. Disassembling Nokia E71 Complete disassembly: 步骤 13 中的图像 1,1
    • I think that two small blocks are the gps antenna.
  14. Disassembling Nokia E71 Complete disassembly: 步骤 14 中的图像 1,2 Disassembling Nokia E71 Complete disassembly: 步骤 14 中的图像 2,2
    • Both sides of battery - for reference only.
结论
33等其他人完成本指南。
4指南评论
does anyone know if e71 have any battery on board? time and date keep resetting with battery removed.
cyfcyf - 回复
Yes there is, under the keypad, 3/4 of the way down the left side of looking from the front. It is soldered on to the board so take good care.
Samuel Wyatt -
Hi
I have this phone, but I can not charge it ,Because it has short in board ,plus it very short charger soket (female ), i’m use now extirnal charger only
what can i do ?
Dev Abokhadra - 回复
Very clear tutorial !
The pictures are well lit, and the instructions are good :)
Thanks !
James Burton - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 44
总计 34,042
