跳转到主内容
Disassembling Nokia E61i Keyboard
Christopher Patton
Christopher Patton4 其他贡献者
最后更新于 January 28, 2014
10 - 15 分钟
中等
缺少的步骤
你所需要的
工具
  1. Disassembling Nokia E61i Keyboard, Battery: 步骤 1 中的图像 1,2 Disassembling Nokia E61i Keyboard, Battery: 步骤 1 中的图像 2,2
    • First, gather all necessary tools.
    • Remove the back cover to access the battery by pushing the tab on the bottom of the cover.
    • Slide the back cover downwards off of the phone while pressing down on the tab.
  2. Disassembling Nokia E61i Keyboard: 步骤 2 中的图像 1,1
    • Locate the bottom-left corner of the phone where there is a spot to remove the battery.
  3. Disassembling Nokia E61i Keyboard: 步骤 3 中的图像 1,1
    • Lift the battery out using your finger.
    • The E61i uses a Nokia BP-4L standard battery.
  4. Disassembling Nokia E61i Keyboard, Front Cover: 步骤 4 中的图像 1,2 Disassembling Nokia E61i Keyboard, Front Cover: 步骤 4 中的图像 2,2
    • To remove the top of the back cover, pry the sides and pop it off.
    • Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
  5. Disassembling Nokia E61i Keyboard: 步骤 5 中的图像 1,1
    • Remove the cover by pulling it up and off.
  6. Disassembling Nokia E61i Keyboard, Keyboard: 步骤 6 中的图像 1,1
    • Once the front cover has been removed, there is nothing holding the keyboard to the rest of the phone. Simply remove the keyboard from the cover by lifting the keyboard from its interior side.
结论
团队
Cal Poly, Team 9-63, Walters Spring 2011 Cal Poly, Team 9-63, Walters Spring 2011 的会员
CPSU-WALTERS-S11S9G63
5 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 19
总计 1,748
